90 Minute Mud
Old 01-24-2012, 07:07 PM   #21
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Re: 90 Minute Mud
Originally Posted by ohiohomedoctor
Put the heat gun to it and stop stressing out about the small stuff. Why 90, mine as well use topping.....
ohiohomedoctor is offline
Old 01-24-2012, 07:36 PM   #22
www.Atlantic-Drywall.com
JMC1981's Avatar
Trade: Drywall
Rewards Points: 77
Re: 90 Minute Mud
As others have mentioned, the Easy Sand 90 looks wet even when it's dry. If it feels like it is dry, chances are.... it's dry.
JMC1981 is offline
Old 01-24-2012, 07:55 PM   #23
RadRemod's Avatar
Rewards Points: 150
Re: 90 Minute Mud
I've ran into this many times were myself or my drywall guy got 2 coats of hot mud on and then one of topping one day. The next day come back sand it and a corner or low joint didnt get enough heat or airflow and the mud hard enough to sand but not fully cured. I'll put the space heater in the corner or on the spot for awhile until the color matches the rest of the mud. The prime and paint away!
I'm sure its dry by now!
RadRemod is offline
Old 01-24-2012, 09:38 PM   #24
Noprofit Ltd.'s Avatar
Rewards Points: 25
Re: 90 Minute Mud
Yeah, it's weird stuff, it's dry and hard enough to press my knuckle into it without a dent, but it looks a little darker in spots, like it may be wet underneath. It's a little misleading to say its 90 minute when you can't really sand it and prime it for 24 hours. Why can't they just say that ont the product? Being a sole proprietor doing EVERYTHING, I can't really stand there with a heat gun .
Noprofit Ltd. is offline
Old 01-24-2012, 09:41 PM   #25
Drywall & Tape
PrecisionTaping's Avatar
Trade: Drywall, Taping & Stucco
Rewards Points: 250
Re: 90 Minute Mud
You're going to sand 90 as your finish product?....yuck..
goodluck with that..
Whatever happened to regular drywall compound?
PrecisionTaping is offline
Old 01-24-2012, 09:43 PM   #26
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Re: 90 Minute Mud
If I remember right the minute rating is the time you need to give the product before giving the next coat. Most definitely not the time in wich you could paint.
Also it has been a long time since I have read the back of a bag but I do believe it says at least some of this information.
CrpntrFrk is offline
Old 01-24-2012, 10:17 PM   #27
Rewards Points: 25
Re: 90 Minute Mud
It sands fine. Maybe in Canada we have a different product . A little more elbow grease for sure, but I'd rather have that than another day of work waiting for a coat to dry.
Old 01-24-2012, 11:04 PM   #28
Drywall & Tape
Rewards Points: 250
Re: 90 Minute Mud
I guess you probably didnt notice "Canada" under my name.
Im pretty sure our products are the same bro.
At least put a finish coat of mud on man.
You can do that after your 2nd coat of sheetrock dries.
Dont skim with sheetrock. yucky.
Old 01-24-2012, 11:18 PM   #29
Rouerplastering's Avatar
Trade: plastering and sheetrocking
Rewards Points: 75
Re: 90 Minute Mud
Is it just me or are there a lot of guys replying here that don't know the difference between "dry" and "set"?
90 "sets" in 90 minutes. It "dries" according to humidity, temperature, airflow.
A setting type compound will get hard in 5, 20, 45, 210 minutes. But may not be completely dry for days. If there are dark spots, it's definately not dry.
Rouerplastering is offline
The Following 2 Users Say Thank You to Rouerplastering For This Useful Post:
Big Shoe (01-25-2012), Mud Master (01-25-2012)
Old 01-25-2012, 12:13 AM   #30
Rewards Points: 25
Re: 90 Minute Mud
"Sheetrock " is the board. Not the mud. Never seen mud called sheetrock before.
Old 01-25-2012, 12:19 AM   #31
Rewards Points: 25
Re: 90 Minute Mud
And this goes to my original question. What is the point of paying double for hot mud if you still can't paint it for days? Where is the benefit? Yeah, you can bang off three coats in a day but it seems to take three days to dry if you do that, which is the same as doing three coats of regular mud, one per day and half the cost. I wanna get three done in a day, sand and prime the next day, instead of four days!
Old 01-25-2012, 12:24 AM   #32
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,314
Re: 90 Minute Mud
Because it's harder, more stable and is faster. Three coats in one day or one coat on three days??? Cmon you can spring $100 to save $750 in opportunity cost labor (You could be working elsewhere) can't you?
Is that why your name is Noprofit? LOL sorry couldn't resist. I hear what your saying - it makes sense if you're working on your on home.
Metro M & L is offline
Old 01-25-2012, 03:39 AM   #33
Big Shoe's Avatar
Rewards Points: 1,728
Re: 90 Minute Mud
Maybe I can help. Sounds like you may have applied the next coat before the previous one was set up. That will most definatley cause problems curing/drying.
As we've mentioned many times here in the past ''fans'' will speed up the process. You will always see at least one in my truck.
Good luck!
Big Shoe is offline
Old 01-25-2012, 08:17 PM   #34
Drywall & Tape
Rewards Points: 250
Re: 90 Minute Mud
Because you were talking about 90 I assumed you ment sheetrock 90!?
http://www.cgcinc.com/en/products/jo...aspx?pType=DIY
What the heck are you using if not that?
Old 01-26-2012, 04:32 AM   #35
Big Shoe's Avatar
Re: 90 Minute Mud
There are 3 brands of quickset in my area tha I know of.
Sheetrock,National gypsum and the third one escapes me?
Let's hear it guys,what brands do you have in your area. Canada guys always talk about one.
Big Shoe is offline
Old 01-26-2012, 08:43 AM   #36
Grand Rapids Remodeling
Paulie's Avatar
Rewards Points: 2,052
Re: 90 Minute Mud
Well here's your first look!
Paulie is offline
Old 01-26-2012, 09:22 AM   #37
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
Re: 90 Minute Mud
Sheetrock is made by CGC ( canadian gypsum company ) I have no idea if it is available in the US.
I'm sure our products are very similar. I use their "sandable 90".
katoman is offline
Old 01-26-2012, 10:19 AM   #38
Trailer park boy
shanekw1's Avatar
Rewards Points: 371
Re: 90 Minute Mud
Synko Pro Set 30 or 90, made by CGC.
"Industry without art is brutality"
shanekw1 is offline
Old 01-26-2012, 05:50 PM   #39
CrpntrFrk's Avatar
Re: 90 Minute Mud
This stuff is very smooth. I would compare it to Hamilton brand. Very similar.
Old 01-26-2012, 05:55 PM   #40
Drywall & Tape
Rewards Points: 250
Re: 90 Minute Mud
ya see....i've never even heard of synco. lol.
Never heard of westpac fast set lite either. Crazy how much stuff there is out there.
Which more or less all does the same thing.
Sheetrock 90 is what I use.
And I dont even like that!!
I only ever use fast setting compounds if I need to catch something up.
Something that was added later or a quick repair.
CGC Machine Mud! Hands down! Best ever! So smoothe!!
So easy to work with!! Flawless finish
Last minute Christmas present. App-ironworks Specialty Trades Picture Post 11 01-29-2012 05:44 AM
Last minute Kent Whitten Carpentry Picture Post 36 11-24-2011 01:27 PM
5 minute chocolate mug cake Willie T Off Topic (Non Trade) 9 10-03-2011 05:22 PM
Paying bills early vs holding till last minute Techie Business 24 10-02-2009 10:42 PM
