45 Degree Joints
Old 02-06-2010, 06:14 PM   #1
taylorconst's Avatar
Trade: remodeling, siding, windows, decks
Rewards Points: 75
45 Degree Joints
I bid on a attic job that the ho wants sheet rocked and finished. My question is when you mud the angles what is the best way to make that joint perfectly straight?
taylorconst is offline
Old 02-06-2010, 06:19 PM   #2
lbsrdi's Avatar
Rewards Points: 75
Re: 45 Degree Joints
I would use a corner blade. If you use it at the correct angle it will turn out great. You might have to bend it depending on the angle of the corner. No problem.
Check out my pictures. http://www.caseysbuilding.com
lbsrdi is offline
Old 02-06-2010, 06:28 PM   #3
genecarp's Avatar
Rewards Points: 2,000
http://www.trim-tex.com/
Try these guys, GMOD
genecarp is offline
Old 02-06-2010, 06:40 PM   #4
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
I used some of their 45 corner bead the other day. come out really nice.
www.bcconstructionllc.com
BCConstruction is offline
Old 02-06-2010, 06:43 PM   #5
mics_54's Avatar
Trade: contractor
I use ultra-flex no-coat 375 or 450
mics_54 is offline
Old 02-06-2010, 07:21 PM   #6
30 yrs carpentry/drywall
Carpenter Wayne's Avatar
Trade: Interiors/finishes
Rewards Points: 75
Use "Striaght Flex" (10xs better than ultra flex) - it's a thick, hard paper/fiber tape made exactly for the situation you're dealing with (as well as similar situations).
Cost approx. $25 per 100' roll - avaiable at any specialty drywall supply co.
make sure to calculate the extra per roll cost into your bid
http://hstrial-pdsdrywall.intuitwebsites.com/
He who lives on hope - dies of starvation
Carpenter Wayne is offline
Old 02-06-2010, 07:25 PM   #7
Balding quickly
BattleRidge's Avatar
Trade: The big stuff!
Rewards Points: 588
we always use straight flex. Its a little pricey but it works well.
www.battleridgebuilders.com
BattleRidge is offline
Old 02-06-2010, 07:46 PM   #8
d-rock's Avatar
Trade: carpentry/drywall/plaster
Rewards Points: 250
I use straight flex, works great. I snap lines first, to keep everything TIGHT.
d-rock is offline
Old 02-06-2010, 08:06 PM   #9
Rewards Points: 75
Shhhhh - can't give ALL the secrets away!
Old 02-06-2010, 08:12 PM   #10
Rewards Points: 75
Sure he can, I won't tell anybody.
Old 02-06-2010, 08:23 PM   #11
Rewards Points: 75
Ok - since we're giving out ALL the drywall finishing secrets then
in the old days before straight flex/etc.
we used to just snap a line from one end to the other thru the angle (after double paper taping it)
snap a line down the center of the angle, and follow the line on each side from the center with your mud - this creates a perfectly straight line (to the eye)!
Straight flex took care of having to do it that way! Plus it's a lot easier/faster to use, and more durable against cracking/etc.
In a pinch I still use this method though!
Old 02-06-2010, 09:05 PM   #12
mics_54's Avatar
Trade: contractor
Hanging the rock like you have to finish it helps too.
mics_54 is offline
The Following User Says Thank You to mics_54 For This Useful Post:
d-rock (02-09-2010)
Old 02-06-2010, 09:28 PM   #13
Grand Rapids Remodeling
Paulie's Avatar
Rewards Points: 2,052
I worked with a guy that could keep a angle like the one in the thread and make it look great. Me on the other hand NEVER could get a good straight line, looked like shat. We just agreed that he'd do the funny angles and I'd do everything else. I guess my point is some people are just good at it.
I was a better floater though. He stood aside when we had to float a wall or whatever.
Paulie is offline
Old 02-06-2010, 09:29 PM   #14
Rewards Points: 75
Those who've hung/finished these type of attic rooms know that there is no "perfect" hang job when it comes to these type of walls/ceilings. It's almost a 100% guarantee that this attic is in a old (75 to 100+ yr) house and there is no such thing as a "straight line" when dealing with it/them.
I've done dozens of these attics and they're all the same - you end up using straight flex no matter how good you try to hang the rock.
Old 02-06-2010, 09:34 PM   #15
mics_54's Avatar
Trade: contractor
Bet I could hang it so you wouldn't want to finish it.
mics_54 is offline
Old 02-06-2010, 11:39 PM   #16
Rewards Points: 75
[quote=Carpenter Wayne;869486]Those who've hung/finished these type of attic rooms know that there is no "perfect" hang job when it comes to these type of walls/ceilings. It's almost a 100% guarantee that this attic is in a old (75 to 100+ yr) house and there is no such thing as a "straight line" when dealing with it/them.
The house is 95 years old. I don't think there was anything straight in any of these old houses when they built them.
Old 02-07-2010, 02:28 AM   #17
QIC's Avatar
Trade: drywall painting remodeling
if the ho wants it to be perfectly straight ....charge him for it .fix frame,hang rock ,ultra flex it ..coat it up and done deal
QIC is offline
Old 02-09-2010, 09:48 AM   #18
d-rock's Avatar
Rewards Points: 250
Even new construction could be a PITA with these angles. There is no shortcut if you want PERFECT. Snap lines, stand back and use your trained eyes to judge, work in steps to get it perfect. There is no silver bullet.
d-rock is offline
To College Degree or Not to College Degree - That is the question wallmaxx General Discussion 13 12-30-2009 01:47 PM
Azek butt joints holding up? LeonardDB Finish Carpentry 39 11-28-2009 07:30 PM
Question on VCT installation Dan V. Flooring 26 05-13-2009 08:38 PM
Gutter joints leaking JTW Roofing 4 02-13-2009 06:45 PM
Engineering Degree? J Howard General Discussion 14 09-29-2008 09:50 PM
