Trade: Taper
3 Ways
Hey guys is there a tool or something that will allow me to get 3 ways done ahell of alot faster...... It takes so dam long to do them i hate them...
Thanks |
Trade: Drywall, painting, carpentry
Re: 3 Ways
You don't mention how you're doing your 3-ways now, so I'll assume it's by hand, in which case there are a couple of options. The least expensive is a corner flusher. I switched over last year to the Better-Than-Ever system and it really did speed things up because you can coat all sides of the 3-way at the same time. It does have a learning curve, but not too bad. You can apply the mud with either a lambswool corner roller or the BTE mud tube, then use the corner flusher to bed the tape, as well as doing the topping. BTE tools are available from Warehouse Bay.com, All-Wall.com (they don't call them BTE, though), and I think Fantastic Tools.com also has them. Can-Am is another brand of very similar tools.
The other option is a corner box; a little more sophisticated and some more money. This applies the mud and tools it at the same time. I don't have personal experience with the auto tools, but there are plenty of members of this forum who do. Corner boxes are also available from the same suppliers mentioned above. Hope that helps. |
Butt Expert
Trade: Drywall
Re: 3 Ways
Not trying to be a smartass but what's a 3 way??? Are you asking how to mudd the vertical to the two horizontal angle's and make them turn out nice, square and clean?
#4 | |
Fentoozler
Re: 3 WaysQuote:
![]() [BTW, in addition to my pie and pastry devouring skills....I am an electrician]
Trade: Kitchen & Bath
Re: 3 Ways
1 battery powered tool, a pair of handcuffs, a blindfold, a whip, and a fifth of vodka.
Trade: Drywall Taper
Re: 3 Ways |
Handle It!
Re: 3 Ways
Profit is not dirty.
Trade: Residential Drywall and Taping
Re: 3 Ways
thats awesome lmao
Profit is NOT a dirty word....Cheap is.... |
Trade: drywall
Re: 3 Ways
tape with 45 min.... do one side of 3 ways with 20 min...... do other side of 3 ways with 20 min..... skim out..... go home.......
Trade: Taper
Re: 3 Ways
ummm Thanks I think.....
a 3 way is where the wall and ceiling meet at a corner... i like my corners to be perfect. I lay the tape then use a 2-2.5 inch flush head to falten tape then wipe out the excess mud from the "3way" next day or so I tube the angles and flush them out again with a 4" flush head. Now it leaves a build up in the corners (3 way) So I have to take my 6" knife and and very carefully make it beutiful. |
Butt Expert
Trade: Drywall
Re: 3 Ways
Bunch of Fricken
around here...![]() I "pick" my corners by always starting on ceiling and wipe to left, then on the left side go down and the right side wipe to the right. Using this technique you should come out with a nice, tight corner and only have the small line on the ceiling side to touch up before you texture. Second coat is the same but only using a small amount of mudd on the corner of the knife or just enough to fill just past where the wet mudd from the angle box started. I take pride in my corners so lots of times I go the opposite way with mudd on two of the "worst" sides after I have completed my final sand. After a few hundred thousand corners you will get those perfect corners without much fuss. Just try to do it the same way on all your corners so you know what final side will have that one small line that will have to be filled before you spray. |
Butt Expert
Trade: Drywall
Re: 3 Ways |
#14 | |
Re: 3 WaysQuote:
#15 | |
Butt Expert
Trade: Drywall
Re: 3 WaysQuote:
Trade: High Rise Caulk and Insulation
Re: 3 Ways
Always did love a good 3 way.
its not going to get better with straps, or new footings or even aroma therapy.
Trade: Drywall
Re: 3 Ways
I mud all the inside angles using a mechanical corner flusher. then wipe excess mud out of 3-ways. the next day I coat 2 sides of the 3-way with a 4 inch knife, let that set up for a couple hours while I finish somthing else such as the 3rd coat over the screws/fasteners, then go around and finish the 3rd side of the 3-way. Makes a perfect 3-way without any gouging. On custom show homes i'll even carry around a hand held light while mudding the 3rd side to make sure it's perfect. I havn't heard of any special tools nor do I think they'd be even necessary with this technique
#18 |
Jack of All
Trade: Remodels
Re: 3 Ways
Fill your stainless steel mud pan with a couple glops of nice creamy top coat, grab a flexy 6" knife, wipe down the top horizontals and one side of the vertical. Go home, whine about not having more auto finishing tools, have a beer, post on contractor talk a question regarding the purchase of (1) FLAT BOX and (1) corner finishing tool, then go back to the job site tomorrow, apply super glue to all of the horribly painful paper cut like gouges made by the drywall knives on your finger tips, and mix up some more of the creamy topcoat.... then hit the other two sides of your horizontals, and the other vertical.... perfect (and I mean PERFECT) corners every time!
Doug |
#19 |
All American Drywall,Inc.
Trade: Drywall Finisher, Contractor 22 yrs.
Re: 3 Ways
ive done it the exact same way as Brock for 22 yrs and never had a problem. for level 4 or better i will pre-bed all the corners before the
final coat. for 3 total coats. you should be able to pick all the corners in a 2000 sq.ft. house in under 45 min behind an angle box. Chris |
| 101 Ways Clients Will Try to Screw You Over | SethHoldren | Business | 27 | 02-28-2010 12:05 PM |
| Creative ways of getting sub contracts | Fuzzycram | Marketing & Sales | 7 | 08-25-2008 03:45 PM |
| Does anyone know any ways to protect social security number? | Shoman | General Discussion | 7 | 03-04-2008 11:28 AM |
| Plumbers in the United States will soon begin learning greener ways | Terran_Sky | Plumbing | 8 | 09-09-2007 10:00 PM |
