24" Oc ?
Old 05-02-2009, 09:36 AM   #1
John1's Avatar
Trade: RESIDENTIAL REMODELING
24" Oc ?
On small room ceiling (10X12' room) if all joist are level can I get away with not "strapping" if I use 1/2" and run perpendicular to joists?
It worked for 20 years but the concensus is 16" oc with 1/2", any thoughts?!
Thanks
John
John1 is offline
Old 05-02-2009, 09:48 AM   #2
Lack Of All Trades
Darwin's Avatar
Trade: Professional handyman services
Re: 24" Oc ?
'Strapping' is meant to evenly distribute floor loads so the joists distribute weight evenly. How is using 1/2 furring perpendicular to the joist going to stop load distribution?
I would just add the strapping--done correctly to code-- and charge what it is worth to you.
Good Luck.
Darwin is offline
Old 05-02-2009, 09:53 AM   #3
JonM's Avatar
Re: 24" Oc ?
For less then 50 bucks....strap it...unless you like returning to do repairs.
JonM is offline
Old 05-02-2009, 09:54 AM   #4
John1's Avatar
Re: 24" Oc ?
Good Luck.
I have alway strapped with 1X4 on 16" oc. I meant in this case just to run the drywall without strapping since the room is small. What aI siad was confusing I think.
John1 is offline
Old 05-02-2009, 10:02 AM   #5
Lack Of All Trades
Darwin's Avatar
Re: 24" Oc ?
I get what you are saying... you just want to lay a drywall ceiling over existing strapped joists--like in a basement. Your method in this case would be fine...
Darwin is offline
Old 05-02-2009, 10:03 AM   #6
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: 24" Oc ?
'Strapping' is meant to evenly distribute floor loads so the joists distribute weight evenly. How is using 1/2 furring perpendicular to the joist going to stop load distribution?.
I believe is talking about drywalling a ceiling, and the issues of drywall sag down the road.
Mike Finley is offline
Old 05-02-2009, 10:12 AM   #7
John1's Avatar
Re: 24" Oc ?
Mike, what is "down the road" in years and the there is only 24" original joist, no strapping.
This is a rental house.
Thanks for all replies!
John
John1 is offline
Old 05-02-2009, 10:16 AM   #8
K2's Avatar
Re: 24" Oc ?
Strapping is kind of a New England thing and not done much in other parts of the country. It's not in the ubc and I don't think it's in the irc.
10x 12... add a couple of 2x4 nailers and make it 12"centers.
K2 is offline
Old 05-02-2009, 10:16 AM   #9
Drywall & Painting Pro
Sir Mixalot's Avatar
Trade: Hang, Finish, Texture, Paint, and Repair.
Re: 24" Oc ?
You should either use 1/2" ceiling board or 5/8" when attaching to a ceiling with framing that is 24"oc.
Sir Mixalot is offline
Old 05-02-2009, 10:19 AM   #10
Trailer park boy
shanekw1's Avatar
Re: 24" Oc ?
Use ceiling board and forget about the strapping.
shanekw1 is offline
The Following User Says Thank You to shanekw1 For This Useful Post:
Mike Finley (05-02-2009)
Old 05-02-2009, 10:23 AM   #11
Chief Toilet Mover
Re: 24" Oc ?
Um they don't make that stuff, I know because Home Depot doesn't carry it.
The Following User Says Thank You to Mike Finley For This Useful Post:
joasis (07-05-2009)
Old 05-02-2009, 10:47 AM   #12
Trailer park boy
shanekw1's Avatar
Re: 24" Oc ?
shanekw1 is offline
Old 05-02-2009, 11:56 AM   #13
PeteL's Avatar
Re: 24" Oc ?
Go with 5/8" and call it a day.
www.wecleanit.biz
PeteL is offline
Old 05-02-2009, 01:25 PM   #14
Thom
thom's Avatar
Re: 24" Oc ?
Here in NM we typically don't strap 24" OC ceilings and have no problems. Maybe it's a moisture thing. Our humidity is quite low.
5/8 @24" OC just might be a problem. It used to be that the manufacturers required 5/8 to be fastened at 16" OC.
Under the UBC we had to strap the garage ceilings (living space above) if the framing was 24" OC because 5/8 was mandatory. Then IBC dropped the 5/8 requirement so we went with 1/2" and no strapping. Then the local code added the 5/8 requirement but approved 24" OC for it.
My head hurts.
thom is online now
Old 05-02-2009, 02:11 PM   #15
John1's Avatar
Re: 24" Oc ?
If the current joist are level on the ceiling, using 2X4's between the current joists seems like a great idea, anyone?
Thanks
John1 is offline
Old 05-02-2009, 02:21 PM   #16
Trailer park boy
shanekw1's Avatar
Re: 24" Oc ?
I'd still just use 1/2" ceiling board. Why waste all the time?
shanekw1 is offline
Old 05-02-2009, 04:55 PM   #17
John1's Avatar
Re: 24" Oc ?
What is "ceiling board"?
John1 is offline
Old 05-02-2009, 05:01 PM   #18
Chief Toilet Mover
Re: 24" Oc ?
A special stronger kind of drywall made for ceilings so you don't have to worry about whats worrying you. You'll have to get it through a drywall supply yard.
shanekw1 (05-02-2009)
Old 05-02-2009, 05:30 PM   #19
Trailer park boy
shanekw1's Avatar
Re: 24" Oc ?
What Mike said, although all the lumber yards here carry it.
shanekw1 is offline
Old 05-02-2009, 05:55 PM   #20
Re: 24" Oc ?
Check this out.-------> USG ceiling board
pulldown stairs and roof trusses 24" oc ezj62 Roofing 14 01-30-2009 09:23 AM
12" versus 24" bucket Driftwood Excavation & Site Work 14 04-26-2007 09:42 AM
