24 Inch Ceiling Joists
Old 10-23-2007, 11:46 AM   #1
EVIL GENIUS
Michaeljp86's Avatar
Trade: General Contractor, electrical, fabrication, & welding
Send a message via AIM to Michaeljp86
When you have 24 inch spacing on the ceiling joists do you need to run a bead of adhesive down it? I was told your supposed to but the only thing I can find in my books is screw spacing. They didnt get me my IBC book yet.
Michaeljp86 is offline
Old 10-23-2007, 12:01 PM   #2
Brocktologist llc.
Brockster's Avatar
Trade: drywall
Re: 24 Inch Ceiling Joists
I've never heard of having to glue the rock onto a joist. I have seen a lot of channel installed to close up the joist space. you install it the opposite direction of the joist.
Brockster is offline
Old 10-23-2007, 12:08 PM   #3
It needs to be 5/8" board.
You mean 1X strapping?
neolitic is offline
Old 10-23-2007, 05:07 PM   #4
kgphoto's Avatar
Trade: Residential Remodeling
That or hat channel
kgphoto is offline
Old 10-23-2007, 05:50 PM   #5
Capt-Sheetrock's Avatar
Trade: Drywall
unless codes have changed recently, 1/2 on 24" meets code. 1/2 sag resistant will give you a better ceiling (stiffer) and of course 5/8 will give you an even stiffer one, but regular 1/2 meets code (even tho most people don't think it does). You can check with your local building infector if you feel the need.
Capt-Sheetrock is offline
Old 10-23-2007, 07:08 PM   #6
Thom
thom's Avatar
We do 1/2" 24" oc without adhesive as standard.
Did it in my own house 24 years ago and it's just fine. It doesn't sag between joists.
thom is online now
Old 10-23-2007, 09:35 PM   #7
oldrivers's Avatar
Trade: drywall applications
on ceiling trusses that are 24 on center there is a vapor barrier so glue wouldnt work there so i cant see why you'd need it on any other ceiling without a vapor barrier.
oldrivers is offline
Sistering Sagging Floor Joists.... AllGoNoShow Construction 22 02-25-2011 04:37 PM
Framing Roof Joists for Addition when top Plate is not Level personalt Framing 3 07-20-2007 06:52 AM
Raising ceiling height in the LR and D- room. marcotte64 Construction 2 04-02-2006 10:33 AM
Vaulted ceiling/no ceiling joists medusa Framing 8 12-22-2005 01:57 PM
