Trade: Jack of most
Wondering If I Can Mix A Color Into Cement
Let's say I have a bag of cement that's a light gray color. I'd like it to be more of a light beige color. Can I add something to the mix to achieve a different color like that? Or do I need to try to find a stone laying cement precolored? I'd like to use my existing bags of cement to limit waste, that's why I'd like to just change the color.
MarQ Remodeling (no website) |
Trade: Mold Remediator, Decorative Concrete, Bamboo Fencing,
Re: Wondering If I Can Mix A Color Into Cement
HERE IS A WHOLE LOT OF INFORMATION ON COLORING CONCRETE.
http://www.concretenetwork.com/concr...ete/index.html
IAQM
www.iaqm.com Elite Concrete Finishing www.eliteconcretefinishing.com Elite Bamboo Products www.elitebambooproducts.com |
You won't get it any lighter with dye, but you can make it a tan or buff color. It will be a very bright yellow powder. Here is a pic of one called "Texas Buff" (Lambert Southwest), which is the lightest color I have been able to make using gray mortar.
Trade: Jack of most
Hmmmm. I guess I'm just looking for a general color of tan or biege to add to the cement that I'm using in between the stone work. Do they sell general colors like that at a local home improvement or hardware store? or do I need to order this stuff online?
They will only have brown, red, and black at most big boxes. Find a stucco or masonry contractor supply house for a wider range (and better price) in stock.
You can also play with latex paint pigments, available at your local paint store.
Play with a few small batches to determine the ratio. Mix the concrete first and then add the pigment.
Trade: Jack of most
Really? Wow, I'll give that a try as well. Thanks.
Trade: Ex-Stucco contractor
You use mortar colors to tent stucco. Go to a material yard that sells stucco and brick products not the new big box stores and they should be able to help you!
It sounds like you will need some dark buff. E-mail me I have a link for you but I can not post it I do not have enough post yet. Last edited by stuccoman; 09-06-2006 at 10:58 AM. |
Trade: Jack of most
Isn't dark buff a reddish color? I saw 'buff' at Ace Hardware this morning and it looked red to me.
No not any dark buff I have ever seen. It was more deep tan/brown.
Trade: Jack of most
Ok, I see it in this color sample here. That's still too dark. I'd like to get a really light tan color. Very light.
http://www.solomoncolors.com/concreteclrs.htm
They have a section for stucco colors. What you are seeing is fo the concrete color or brick mortar.
Trade: Jack of most
I'm not doing stucco work, I'm doing stone work. I need the color of the mortar in between the stones to be a light tan to match existing work.
Ok. Trial and error might be the best thing. Mixing samples. You should still be able to get what you need at the material yard. Do you have a peice of the moratr that you can take to the yard with you?
Trade: Jack of most
Yes I do. I was planning on trying the paint tip first and then if that didn't work for me, I would go to my local stone yard and bring a sample with me.
Thanks.
| Fiber Cement almost same cost as Vinyl? | MKECONTRACTOR | Windows, Siding and Doors | 17 | 12-20-2008 06:34 PM |
| Transitioning drywall with cement board | Lone Wrencher | Drywall | 19 | 03-02-2008 07:05 AM |
| drywall mud over cement? | mudgirl | Construction | 7 | 07-20-2007 08:27 PM |
| 2" Cement cap (floor) | copusbuilder | Flooring | 8 | 12-11-2005 01:55 AM |
