Will This Work?
Old 10-19-2017, 10:49 AM   #1
3D Signs's Avatar
Trade: Sign Manufacturer
Rewards Points: 56
Will This Work?
The monument sign I am building is to have "columns" at each end which project out from the main structure by 4'' as in the image....
3D Signs is offline
Old 10-19-2017, 10:55 AM   #2
3D Signs's Avatar
Rewards Points: 56
Re: Will This Work?
I am planning to make the 4'' projections with 4''block like this, reinforced with the brick ties in the photo. Do I need to mortar the whole back and side of each 4'' block to get a good bond? Should I use a special mortar? Or will the type S I'm using be sufficient? Thanks!
3D Signs is offline
Old 10-19-2017, 11:08 AM   #3
Windycity's Avatar
Trade: Masonry
Rewards Points: 5,756
Re: Will This Work?
Should be sufficient to tie them together with the wall ties.
Windycity is online now
The Following User Says Thank You to Windycity For This Useful Post:
3D Signs (10-19-2017)
Old 10-19-2017, 11:15 AM   #4
rblakes1's Avatar
Rewards Points: 1,330
Re: Will This Work?
I thought tubes of PL were the only way to do block work
Sent from my SM-N910V using Tapatalk
rblakes1 is offline
The Following 2 Users Say Thank You to rblakes1 For This Useful Post:
3D Signs (10-19-2017), Fouthgeneration (10-20-2017)
Old 10-19-2017, 11:42 AM   #5
Windycity's Avatar
Trade: Masonry
Re: Will This Work?
Lol that won't work considering the part already built has mortar joints the pl system might be a little bit low
Old 10-19-2017, 11:49 AM   #6
3D Signs's Avatar
Rewards Points: 56
Re: Will This Work?
Are you saying PL would have been better to build the whole thing?
3D Signs is offline
Old 10-19-2017, 12:01 PM   #7
Windycity's Avatar
Trade: Masonry
Re: Will This Work?
No he was probably referring to this
Gluing cinderblock walls with PL premium?
https://r.tapatalk.com/shareLink?sha...4&share_type=t
The Following 2 Users Say Thank You to Windycity For This Useful Post:
3D Signs (10-19-2017), rblakes1 (10-19-2017)
Old 10-19-2017, 12:54 PM   #8
3D Signs's Avatar
Rewards Points: 56
Re: Will This Work?
Thanks, I will just keep going with the type-S mortar.
3D Signs is offline
Old 10-20-2017, 02:57 AM   #9
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 6,223
Re: Will This Work?
Type S mortar should get you about 1200 + PSI mortar strength in compression, Thus 8 inch high joints a 3/4" wide on each end of the 4" Unit would give ~12 square inched of mortar or 14,400 lbs of compression before failure(evenly applied).......
Rule of thumb allows 400 PSI vertically loads, 4 x 16" CMU = 12.8 tons.
Quit asking questions and FINISH this pig before your wife leaves you.
Don't let the pursuit of perfection stop the production of Good or excellent.
Fouthgeneration is offline
The Following User Says Thank You to Fouthgeneration For This Useful Post:
3D Signs (10-20-2017)
Old 10-20-2017, 07:41 AM   #10
Windycity's Avatar
Trade: Masonry
Re: Will This Work?
Is the stone that you're using real stone? Or thin veneer stone?
Old 10-20-2017, 09:38 AM   #11
3D Signs's Avatar
Rewards Points: 56
Re: Will This Work?
Veneer; Cultured Stone http://www.boralamerica.com/cultured...stone-by-boral
3D Signs is offline
Old 10-20-2017, 04:39 PM   #12
Windycity's Avatar
Trade: Masonry
Re: Will This Work?
Cool, keep posting pictures as it progresses! Looking good so far
Old 10-20-2017, 08:26 PM   #13
JBM's Avatar
Trade: Masonry
Rewards Points: 4,422
Re: Will This Work?
No your in florida where column block are a dime a dozen. You also need to build it for hurricanes.
Lay column block, cut keyway in to a couple of them, , cut beams into keyway, run steel continous.
JBM is offline
Old 10-20-2017, 08:27 PM   #14
JBM's Avatar
Trade: Masonry
Re: Will This Work?
Laying it like that is sheot for florida.
JBM is offline
Old 10-20-2017, 08:33 PM   #15
JBM's Avatar
Trade: Masonry
Re: Will This Work?
If it were me I would have transition bars into the columns too...
JBM is offline
Old 10-20-2017, 09:38 PM   #16
3D Signs's Avatar
Rewards Points: 56
Re: Will This Work?
It has #5 rebar, sunk 2.5' into the 8.5 yd monolithic foundation and sticking up 2.5' into the block. It has a bond beam of 2 parallel sticks of #5 rebar running end to end. It also has Durwall wire in every course except the one with the bond beam. When I get 4 courses higher, I will install another bond beam and when all the block is laid I will drop in #5 and #4 rebar then fill the whole thing with concrete and drop a vibrator in each hole to make sure it fills every corner and crack. If the hurricane gets it, oh well.
3D Signs is offline
The Following User Says Thank You to 3D Signs For This Useful Post:
JBM (10-23-2017)
Old 10-26-2017, 04:22 PM   #17
Master Mason
RacinMason's Avatar
Trade: Masonry
Rewards Points: 110
Re: Will This Work?
Probably should've laced the 4" block in with the wall block, would never move that way. It should be fine for cultured stone though, especially with that massive foundation.
650cc on the track
800cc on the snow
1000cc on the street
RacinMason is offline
The Following User Says Thank You to RacinMason For This Useful Post:
3D Signs (10-26-2017)
Do you believe the customer is always right? Mike Finley Business 49 05-04-2015 03:44 PM
Looking For Commercial Painting Crew for work in Highlands, NC rdr8887 Help Wanted or Looking For Work 2 03-23-2013 01:12 PM
Coolest Work Truck up for Sale Brimar Vehicles 23 02-01-2013 10:31 AM
Is there an uptick in homeowners/scammers happening or am I going nuts? workingintx Business 19 11-14-2012 11:57 PM
Poor framing/concrete pad work from contractor netlinks Construction 10 10-26-2012 06:44 PM
