What Is The Proper Way To Install Brick Steps Against The Band Around The House?
Old 03-07-2008, 08:28 PM   #1
Designing YourImagination
TurnkeyConst's Avatar
Trade: Custom Remodeling
Hey well I have constructed a 12x16addition and the band is 2x10size. What is the proper way to flash for the steps to go up to the threshold of the 3/0 door. I have currently installed galvanized flashing where the steps would meet the house and siliconed it in where there is a chance of water getting behind it. I have not built brick steps before but me and my father are going to build these after our current mason screwed the foundation. not happy at all. Does anyone have any how-to articles on building brick steps or best to purchase a book? We have all the tools because my father has done some small brickwork in the past but never steps. I poured a 4'x3'x8" footing to support the steps. It will be 3 steps 8" rise, top step 16" deep and then the rest 11" deep. IF anyone could help me would appreciate it. Or if there is a mason around sanford nc that would like to come help me out and teach us a little would be up for it. Just tired of getting screwed by masons, its our 3 bad mason which all had great references. what else do you do. thanks alot.
TurnkeyConst is offline
Old 03-07-2008, 08:58 PM   #2
Tscarborough's Avatar
Re: What Is The Proper Way To Install Brick Steps Against The Band Around The House?
You get what you pay for, especially when you do it yourself.
Tscarborough is online now
Old 03-07-2008, 09:24 PM   #3
(pics would help)
Old 03-08-2008, 02:39 AM   #4
Tommy C's Avatar
Trade: Mason
Send a message via AIM to Tommy C
Turnkey,
If you've never done brickwork before, a set of steps will be a challenge. If you must do it yourself, I would say buy a book on basic masonry technique, or google some how-to stuff online. Best bet, however, is to hire a mason!
Tommy C is offline
Old 03-08-2008, 06:40 AM   #5
hey there
well the first response i knew i was going to get is hire a mason so which i expected to get. i understand that i might be crazy to try to build steps for my first time. but the thing is that all the masons i have hired think they can come do a crappy job and then jack the prices up on me. so i am getting sick of it. ill do these steps because if it doesnt look like what i want them to look like i will tear them out and do it again until it is right, but i am not going to pay someone else to come in here and screw them up for me. I have attached a picture. I hope it helps. not that I am saying all masons are screw ups but it seems this dang recession is bringing out the best of them in my area. my work is my name and I would like to keep it that way but 1 mason could ruin it.
What is the proper way to install brick steps against the band around the house?-stepsdiagram2.jpg
Old 03-08-2008, 08:14 AM   #6
menber
masonking02's Avatar
Trade: bricklaying
so why come on here to look for a mason response sounds like u really got it in for us , leave the steps to the pros they go far beyond the basics of brickwork ,
masonking02 is offline
Old 03-08-2008, 09:01 AM   #7
My experience over the last 30 years and 3 or 4 recessions is that the good contractors keep working and earning a living and the marginal or crappy ones take jobs like this for starvation wages, so we are back to my original post.
Old 03-08-2008, 09:23 AM   #8
Can't help you with the brick work,
or finding a good mason.
I can tell you that lead is the traditional
flashing material if you care about l
longevity.
If you are going to use the galvanized
maybe you could cover it with
ice and water where it is in contact
with the masonry.
Concrete and mortar contact tends
to rot the galvanized prematurely,
and be sure you leave a breathing space
where the wood siding meets the masonry.
neolitic is offline
Old 03-08-2008, 11:35 PM   #9
I don't have anything out for you guys and don't have anything against anyone. I don't mind hiring a good mason to do the job. I just am getting tired of getting screwed so I figure the main thing is that if I can figure out the proper way to flash it is the first step. Then if I screw up the construction of the steps I can fix them cheaper than I can pay someone else to screw them up. The job is in sandord nc. I can do the flashing in lead I guess will have to find out where to find it. I will purchase a book on it to see if it will shine some light on it. I don't mind paying for a good job. Currently. I pay 425 per 1000 and 1.50 per block. Plus material. Have payed as little as 325 per thousand. Is this not what I should be paying for good work. Well let me know and possibly where to look for someone decent. I appreciate all the criticism because I am young but willing to learn, but not afraid of trying anything especially If it helps me to identify someone elsea crappy work. Hope you gutta have a good weekend and look forward to hearing from you!
Old 03-09-2008, 03:52 PM   #10
Al Smith
A W Smith's Avatar
I wouldn't use just metal. I would use Grace Vycor
And right away I see by your illustration that your first step is too low. In masonry, Multiples of eight prevail. which may mean compromising the door threshold to porch slab height to something less than 8 inches. And the top slab needs to be 4' X 4' minumum.
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 03-09-2008, 04:07 PM   #11
I've used the Grace in a pinch,
seems like a good solution if
you don't have to fish it in behind
existing siding.
Plumbing supply or roofing supply
houses carry sheet lead.
neolitic is offline
Old 03-09-2008, 04:37 PM   #12
CR2's Avatar
Trade: Stone,brick,block,concrete,decorative concrete..
Turnkey, NC is a State where masonry is big and tons of skilled masons make a living working in high end quality jobs,offering superb craftsmanship(there are a bunch of loosers too, like anywere else); you should spend time finding a good mason instead of doing, tearing out and redoing steps, your job is to hire the right mason and not to do the job, it will be cheaper for you if you take more time to find the right guy.
Good Luck!
CR2 is offline
Old 03-12-2008, 04:33 PM   #13
BC Maryland's Avatar
Trade: licensed masonry contractor in Maryland
In Maryland code calls for a landing at the top. For flashing you should of had a piece of copper or other material bent on a brake and use that on top of the brick and behind the siding where it meets the brick. But unfourtunetly you already sided the house so the flashing wont tuck up into the wall properly.
BC Maryland is offline
House moving Toolwh@#e Excavation & Site Work 10 10-21-2007 11:23 PM
what 2 use 4 water line to house? national Plumbing 15 10-04-2007 11:31 PM
`Flip This House' star accused of fraud AmeliaP General Discussion 28 06-03-2007 10:21 PM
1950s Brick Ranch, No insulation but weird plaster type drwall. personalt Construction 5 01-21-2007 07:49 PM
Landscape solution to basement moisture problem RJC Construction 3 11-21-2005 01:34 AM
