What Kinda Flashing Does Everyone Use?
Old 04-11-2007, 10:16 AM   #1
turbomason's Avatar
Trade: Mason
Question
I was wondering what type of flashing everyone uses for brick veneer houses on the foundation and behind brick lentels? wow theres been alot of posts since last time i was here! I guess i must have gotten busy.
turbomason is offline
Old 04-14-2007, 11:46 AM   #2
turbomason's Avatar
Trade: Mason
Re: What Kinda Flashing Does Everyone Use?
Well either noone flashes there foundations and angle irons or maybe this post has already been discussed? some feedback would great!
Old 04-14-2007, 10:08 PM   #3
CR2's Avatar
Trade: Stone,brick,block,concrete,decorative concrete..
You're right, at least arround here, no residential jobs are getting any masonry flashing( even $$$$$$$$$$ houses), that's reserved for commercial work, I know it's not right, but it's true; it must be a money issue( too expensive).
CR2 is offline
Old 04-15-2007, 11:11 AM   #4
Mason
bruno002's Avatar
Trade: Masonry
we use vinyl flashing
bruno002 is offline
Old 04-15-2007, 11:26 AM   #5
stacker's Avatar
Trade: masonry
never flash residential around here.only chimenys
stacker is offline
Old 04-18-2007, 08:33 AM   #6
Dik Redi's Avatar
Trade: Masonry
We use Vinly flashing on the lentels and brick shelves, we recommend led coated copper Thru wall flashing for all our Chimneys that come up thru house, and if on side of house we use just reg. led flashing unless its a stone veneer, then we recommend led coated unless the Home owner or Genral Cntrctr say its cost to much, which is the case most times. RI here
Last edited by Dik Redi; 04-18-2007 at 08:34 AM. Reason: forgot to put my lacation
Dik Redi is offline
Old 04-29-2007, 07:23 AM   #7
CJKarl's Avatar
Trade: Masonry
What he said.
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Old 04-29-2007, 10:15 PM   #8
Dik Redi's Avatar
Trade: Masonry
Originally Posted by CJKarl View Post
What he said.
TY CJ,, always glad to see someone who knows and respects quality,, and u being up here ,,you know we need it ,, esply afta that last NOR`Easter, wind can make water go where it wants.
Dik Redi is offline
Old 05-13-2007, 12:55 PM   #9
menber
masonking02's Avatar
Trade: bricklaying
rubber flashing along with tube weep holes for drainage
masonking02 is offline
Old 05-13-2007, 07:26 PM   #10
Dik Redi's Avatar
Trade: Masonry
yes , forgot too mention the weepz, we use the waffer weeps every 3 bricks
Dik Redi is offline
Old 05-13-2007, 10:00 PM   #11
menber
Trade: bricklaying
every 3 bricks here as well .
Old 05-20-2007, 03:48 PM   #12
Fabbrimasonry's Avatar
Trade: FabbriMasonry
Send a message via AIM to Fabbrimasonry
ipco flashing...self adhesive backing. Dont forget to use the betylethelye (TAR) when adjoining two pieces and end dams. Do it right. or don't do it. At the base use Mortar net or else mortar will just block weeps.
Fabbrimasonry is offline
Old 05-20-2007, 06:29 PM   #13
Dik Redi's Avatar
Trade: Masonry
just used that mesh on a church for the first time, i see the purpose but let me tell you what a hassle ,, but after you past it you are back to normal production,, And with the damns, ive seen them and worked along masons that used them but if you flashen well and put weeps where theyre needed should be no worries(( i over lap lentel no less then 6 "s , gives a good lentel flashing over door/window jam
Dik Redi is offline
Old 05-22-2007, 06:03 PM   #14
menber
Trade: bricklaying
those dams are becoming real popular up north , there really something to get used too , i worked on a wall with the dam going all the way to the top of the wall , i guess the roofers needed it for a roof line . what a pain in the ass , almost lost my job behind it
Old 05-24-2007, 10:53 PM   #15
Dik Redi's Avatar
Trade: Masonry
masonK , u eva use the mortar mesh?? ( hASSle)
Dik Redi is offline
Old 05-25-2007, 08:16 AM   #16
menber
Trade: bricklaying
r u talkin bout the stuff that looks like grass
Old 05-25-2007, 09:54 PM   #17
Dik Redi's Avatar
Trade: Masonry
lmao yes grass castle looken
Dik Redi is offline
Old 05-25-2007, 10:10 PM   #18
menber
Trade: bricklaying
lol
Flashing around a chimney Barry M Roofing 218 01-27-2010 03:12 PM
weatherhead flashing boman47k Roofing 9 11-10-2007 12:09 PM
installing new thru-wall flashing @ existing wall. TAO Masonry 5 08-08-2007 05:26 PM
Step Flashing Hardibuilt Roofing 3 05-18-2007 02:08 AM
still trouble with flashing Traditions Painting & Finish Work 20 01-31-2007 09:01 AM
