This Is What I Need To Do.
Old 02-19-2009, 06:39 PM   #1
ruskent's Avatar
Trade: Outdoor D/B
So this friend of mine has a stamped concrete pool deck. Expansion joints were saw cut in and then filled with mortar. After 7 years the joints are all very cracked. What is the best way to repoint these joints. Is there any addative I could add to make the mortar less prone to cracking?
ruskent is offline
Old 02-19-2009, 06:49 PM   #2
ruskent's Avatar
Trade: Outdoor D/B
Re: This Is What I Need To Do.
BTW joints are 1" thick.
ruskent is offline
Old 02-19-2009, 07:18 PM   #3
Tscarborough's Avatar
Remove the mortar and do them the correct way with a high quality polyurethane caulk. BTW, make sure that a primer is used and be absolutely sure that the caulk profile is as designed. That way they will last 10 years instead of 1.
Tscarborough is offline
Old 02-19-2009, 07:56 PM   #4
ruskent's Avatar
Trade: Outdoor D/B
What does this chauk cost and do you have any links to companies that make high quality chauk.
ruskent is offline
Old 02-19-2009, 08:26 PM   #5
Google NP1 by sonneborne. Pay close attention to prep and joint design. It isn't cheap, not it is nowhere near as expensive as repairing it again in a couple of years.
Old 02-20-2009, 12:30 PM   #6
CaliDesigns's Avatar
Check out Vulkum. The have a good primer. You could also "sand" the caulk to make it look more like a mortar joint.
CaliDesigns is offline
