Webinar On Fiber Re-bar.
Old 02-14-2018, 05:36 PM   #1
fjn's Avatar
Trade: mason
Rewards Points: 9,140
I have been looking into the use of fiber re-bar for awhile. It seems like a much better product than any of the steel products,either coated or non coated . I have yet to use any,however,been giving it considerable consideration. Here is a connection to a free webinar coming up on Feb.22 ND.
http://www.nthconsultants.com/use-of...m_medium=email
fjn is offline
wazez (02-14-2018)
Old 02-14-2018, 09:20 PM   #2
JBM's Avatar
Trade: Masonry
Rewards Points: 4,502
Re: Webinar On Fiber Re-bar.
Is it made in the us?
JBM is offline
Old 02-15-2018, 12:39 AM   #3
Anti-wingnut's Avatar
Rewards Points: 3,310
Where would you consider using it? At present, it seems like it is meant for areas of high corrosion and loads, like bridges. Seems like there is no need in residential of multi-family.
Anti-wingnut is online now
Old 02-15-2018, 03:29 AM   #4
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 12,977
A random find for the curious... Interesting stuff.
http://www.fdot.gov/design/Training/...Composites.pdf
MarkJames is offline
fjn (02-15-2018)
Old 02-15-2018, 09:42 AM   #5
fjn's Avatar
Trade: mason
From what I have discovered,yes it is.In the good states of Florida,Texas and Washington,along with our neighbors too the north in Canada.
fjn is offline
Old 02-15-2018, 09:54 AM   #6
fjn's Avatar
Trade: mason
Probably as a substitute for steel in most applications. From the discussions I have had with people in the field,it overcomes the problems with steel in several ways. It seems most importantly,unlike steel that rusts,expands and spalls the concrete or masonry,when fiber ages,looses some strength etc.,it does not impart the ill effects of spalling.
It may not be the perfect answer,however,from what I understand,it is a step in the better direction.
fjn is offline
Fouthgeneration (02-16-2018)
Old 02-16-2018, 02:14 PM   #7
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 6,383
Rusted Iron and steel is always larger than unrusted(oxidized) Iron, = cracked masonry and reinforced with steel concrete....
There are some interesting basalt based rebars available...
Fouthgeneration is offline
The Following User Says Thank You to Fouthgeneration For This Useful Post:
fjn (02-16-2018)
Old 02-16-2018, 02:17 PM   #8
But where is the deterioration such a problem? Certainly not in houses? This is stuff for bridge decks.
Old 02-16-2018, 05:38 PM   #9
fjn's Avatar
Trade: mason
Well,at only approx. 50% up charge from steel,1/4 the weight,and twice the strength of steel,it seems like a very affordable way to obtain the belt and suspenders approach. Not to mention with the considerable weight reduction,the increase in production one will realize,along with less worker fatigue and more safety.
fjn is offline
Old 02-16-2018, 06:24 PM   #10
artisanstone's Avatar
Trade: Stonemasonry
Rewards Points: 608
Is there a specific product you're talking about? My assumption is GFRP which looks like essentially fiberglass rods.
One huge market should be the cast stone industry. (Huge as in beneficial to them. I don't think it's that big of an industry.) I can't tell you how many failures I've seen. Mainly rebar popping the face. Not structural failure but definitely aesthetic failure. I've been told it's due to the use of calcium choride to speed the process.
artisanstone is online now
The Following User Says Thank You to artisanstone For This Useful Post:
Fouthgeneration (02-18-2018)
Old 02-16-2018, 06:32 PM   #11
fjn's Avatar
Trade: mason
Yes,that is the bar I have in mind. You are correct,the cast stone industry would do well to give fiber a very close look,both the wet cast and dry cast.
fjn is offline
Production cutting fiber cement siding Windwash Windows, Siding and Doors 18 06-20-2013 03:43 PM
fiber cement siding issues. chapstick Windows, Siding and Doors 36 08-30-2012 08:14 PM
Got bored so added some carbon fiber BCConstruction General Discussion 34 07-15-2012 09:45 AM
Fiber Cement Siding question--- enforcer Windows, Siding and Doors 12 01-13-2010 07:29 PM
