Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Masonry
Old 08-26-2009, 10:28 PM   #1
Trade: Landscape Contractor
Waterproof
I am making a water fountain basin for a contractor. First off, I am not a mason but a landscaper. I poured a 10 x 10 slab and hired a friend who is a mason and he built the walls out of 8" block and veneered with brick to match building. Then he parged the inside. The question is what can i put on this to make it waterproof on the inside? I was looking at UGL Drylock Extreme. What do you guys suggest? Thanks in advance.
David
dclark2037 is offline   Reply With Quote
Old 08-27-2009, 07:44 AM   #2
Tscarborough's Avatar
Trade: masonry
First you need to cove out the base of the walls.
To my knowledge, Drylok is not warrantied for horizontal surfaces or for water contact conditions. Check with their technical people before you use it, since it will be almost impossible to do anything else once it is applied.
I would simply use pool plaster anyway.
Tscarborough is offline   Reply With Quote
Old 09-11-2009, 04:14 PM   #3
Trade: Windows Waterproofing
question is how long do you want it to last and what color does it need to be?
UGL Drylock looks like paint to me. for a fountain you need to use either a deck coating NeoGuard or Sonoguard that should last a little while may leak a little bit. If you want it to really last try CIM 1000, its considered a liquid aplied membrane. Its expensive but if you want to do it right this is probaly the only way to go. If you do go this route make sure whoever you buy it from explains how to use the product, you have to work fast when u mix the buckets it sets up in a matter of 20 mins.
But do not use that drylock... anything that is latex based and offers more then a 5 year warranty is garbage...
SealantEngineer is offline   Reply With Quote
Old 09-11-2009, 05:27 PM   #4
tomstruble's Avatar
Trade: siding
hmmm kinda like a concrete koi pond
tomstruble is offline   Reply With Quote
Old 09-11-2009, 05:35 PM   #5
Professiona Instigator
rbsremodeling's Avatar
Trade: Design Build Remodeling Contractor Washington, DC
hydraulic cement at the joints and thoroseal the entire surface
rbsremodeling is offline   Reply With Quote
Red Guard waterproof?? lazerguy Ceramic & Stone Tile 2 06-26-2009 11:28 PM
question about waterproof shingle underlayment at chimney ttboy Roofing 49 03-20-2009 05:19 PM
Anyone have experience with Thoroseal to waterproof bsmt foundation? Jim S. Construction 1 08-26-2008 10:53 AM
Waterproof Systems Guardi Pro Painting & Finish Work 2 08-26-2007 12:23 PM
Storage under deck benches..... waterproof storage TurnkeyConst Decks & Fencing 4 05-23-2007 08:36 PM
