Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Masonry
Old 09-01-2009, 08:34 PM   #1
Trade: Kitchen and Bath Remodeling-Home Renovations
Water Stained Brick Fireplace
I am working in a home that had some water damage due to a busted toilet supply line. The water came down the wall and saturated the red brick fireplace. The mortar is stained brown and the brick doesn't look all that great. Is there a way to clean it with acid or some other solution. Thanks in advance.
Merbs is offline   Reply With Quote
Old 09-01-2009, 08:45 PM   #2
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
Have you tried to just wash it with water and a scrub brush?
Step 2. Soap and water
Step 3. Contact a mason and have him determine the best cleaning solution available.
Not very hard to make the problem worse in this case.
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline   Reply With Quote
Old 09-01-2009, 09:24 PM   #3
CJKarl's Avatar
Trade: Masonry
Acid won't touch it. Go to a fireplace/wood stove shop.
There's Always A Market For Quality
CJKarl is offline   Reply With Quote
Old 09-02-2009, 09:22 PM   #4
Minuteman's Avatar
Trade: Commercial property maintenance, and...
First try a new wire brush with soap and water. If that is no good then try a diluted HCL solution 1:10 and work your way up to a 50/50 solution. If that does not work try Safe-Restore - Prosoco product.
Ken Santell
Owner - Minuteman Building Services, LLC
Houston, TX
H: 281-955-2374
C: 281-793-1935
Vision: Creating legendary customer experiences one business, one employee at a time.
Value: When you work, do it right, do it well, make it fun, be proud of it, and pass it on!
Motto: If we can't improve your business, we won't ask for it.
Minuteman is offline   Reply With Quote
Old 09-10-2009, 09:50 AM   #5
Trade: No
Better dont go for acids because it may further damage the appearance. The best way is to use a mild detergents with a brush. It works
balacbe11 is offline   Reply With Quote
something for the masonry department dakzaag Masonry 2 05-08-2009 09:23 PM
Cultured Stone over Existing Brick Fireplace fakie99 Masonry 7 12-01-2008 06:10 PM
water condensation/ice and watershield altonarch Roofing 5 11-23-2008 10:51 PM
Hot Water Heater making loud sound and vibrating the entire wall BKFranks Plumbing 9 10-27-2008 09:58 PM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 08:48 PM
