Wall Paper Removal Nightmare
Old 09-11-2005, 08:29 PM   #1
juliepe's Avatar
I have a mild disaster, I tried to remove old wall paper most came off ok. I have several spots that I can't seem to dissolve the old paste/paper with the wallpaper remover. I have torn the exterior of the sheet rock and have a ragged mess of stuck on paper. My walls are flat surface. Any ideas of what I can do?
juliepe is offline
Old 09-11-2005, 08:41 PM   #2
6stringmason's Avatar
Trade: masonry
Re: Wall Paper Removal Nightmare
Replace the the parts of sheetrock that need it. Or tear until its off then patch it. BTW... this is the forum that pertains to masonry. Which is concrete, brick, block, stone, etc.. You might not get as many ideas in here as you would in say, normal construction forum, or painting, or remodeling.
6stringmason is online now
Old 09-11-2005, 09:04 PM   #3
Painting Contractor
Humble Abode's Avatar
Trade: Painting Contractor
Send a message via AIM to Humble Abode
I would clean as much of the adhesive as possible off. Use vineger and warm water and spray it on the wall,(the parts with wallpaper adhesive) let it sit for a minute or two and scrape it off with a wide putty knife. Then your going to need to skim coat the patches that have been damaged. Get yourself some joint compound and go to town. You may need to put several coats of the stuff on, be patient and follow the directions for recoat times. A recent bathroom I did took several coats of joint compound and two days to get smooth.
Prime before and after!
Just because some of us can read and write and do a little math, that doesn't mean we deserve to conquer the Universe. Kurt Vonnegut, (1922 - 2007) from the Novel 'Hocus Pocus'
The NAPP
Milwaukee Painting Contractor
Humble Abode is offline
Old 09-11-2005, 09:33 PM   #4
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Juliepe, follow the above advice.
And since you are a homeowner, and not a contractor, this
should be discussed right here.
ProWallGuy is offline
Old 09-11-2005, 10:01 PM   #5
Teetorbilt's Avatar
You may have run into repaired sections and God only knows what the HO or handyman used. I'd break out the orbital sander.
Albert Einstein
Teetorbilt is offline
need person to istall wall paper soldz Wallpaper 18 03-19-2007 06:42 PM
commercial wall paper removal rservices Wallpaper 1 06-28-2006 09:58 PM
wall paper on plywood skylands Wallpaper 2 03-23-2006 10:29 PM
Wall Paper removal nightmare juliepe Drywall 0 09-11-2005 08:50 PM
why primer is bubbling up over wall paper Zeebo Painting & Finish Work 2 07-10-2005 10:11 PM
