Under Pininng /repair
Old 02-01-2008, 01:16 PM   #1
Tom M's Avatar
Whats involved in a repairing a 100 year old field stone foundation? I have a few piers that need be knocked down and can be replaced with block but I also have a deteriorated section of foundation wall, basement stairs and a few old window openings that are all shot. Can you co-mingle block for these repairs? I do not beleive the building is historical and all work is basically below grade. Any advice on what I may be dealing with in these repairs would help. Thanks
Tom M is offline
Old 02-01-2008, 01:49 PM   #2
Al Smith
A W Smith's Avatar
Re: Under Pininng /repair
Whats wrong with the stone thats already there? can it be removed cleaned up and reset? I'm not a mason but I would not be filling in stone with block. Is there fieldstone on the property?
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 02-01-2008, 01:59 PM   #3
Tom M's Avatar
Yea the stone is sill there but I would think carving out the bottom and filling upward may be stronger. I suppose sticking some random stones to fill any void may be easiest but I honestly dont no for sure what the best approach. The whole foundation is pretty shot from what I can see and I would think in the near future more repairs are close.
Tom M is offline
Old 02-01-2008, 03:00 PM   #4
Tscarborough's Avatar
I wouldn't use block other than for the piers and stairs. It would probably be better to use brick or rock. Also note that if you do superficial surface repairs using a portland mortar, you will probably speed up the rate of decay of the interior of the wall by a large factor.
Tscarborough is online now
Old 02-01-2008, 03:19 PM   #5
Tom M's Avatar
Good advice thank you. I will be hiring this out to a mason. I posted to feel out how signaficate the expense may become.
Tom M is offline
