Topping For Concrete Porch Slab
Old 10-17-2007, 01:00 PM   #1
JaxBrad's Avatar
Trade: Residental
Question
I have a circa 1913 bungalow with three steps leading up to a concrete landing at the front porch. Over the years the slab next to the wall has settled about 2 inches. When it rains water puddles up against the brick wall. I was in the crawl space recently and saw a lot of water infiltration and brick deterioration.
Can anyone recommend a masonry topping product whereby I can raise the slab at the wall about 2 inches and then taper it down to the top of the last step? It seems that when I taper down to such a thin layer, just about any masonry product would crack and chip off.
Thanks,
Brad
JaxBrad is offline
Old 10-17-2007, 02:08 PM   #2
kgphoto's Avatar
Trade: Residential Remodeling
Re: Topping For Concrete Porch Slab
Cement-All by Rapid Set is the product that I would recommend.
kgphoto is offline
Old 10-17-2007, 09:29 PM   #3
joecrete's Avatar
Trade: Concrete Overlay Installer
Add bonding primer to the base and before you finish the top enbbed a fiberglass mesh on the surface and broom finish
joecrete is offline
Old 10-19-2007, 07:12 PM   #4
CJKarl's Avatar
Trade: Masonry
Here's the stuff we use in my area. Always had great results.
http://www.silpro.com/
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Old 11-04-2007, 07:52 PM   #5
skinnyj41004's Avatar
Trade: Electrician
Would slab jacking or concrete lifting be an option?
skinnyj41004 is offline
Old 12-04-2007, 01:43 PM   #6
Griffino's Avatar
Trade: General Contracting
Yes I know a guy who used hydrolic pressure and injected epoxies to luft almost anything.
I would suggest top side replacement, you won't regret it. You will even be able to reflash that side of your house too.
I have had bad luck skimming less then a 1/4" of any type of grout/cement and it looking nice and perfoming well.
Griffino is offline
Old 12-04-2007, 09:00 PM   #7
Workin' Hard & Havin' Fun
BreyerConstruct's Avatar
Trade: Deck Designer/Builder
Different route, but we've covered porches with brick, slate, and pavers for height adjustment & aesthetic concerns...
Might not work w/ the slop issue, but maybe build the whole thing up?
~Matt
BreyerConstruct is online now
How to level out a concrete porch? ProVolley9 Masonry 17 08-27-2008 09:09 PM
Help Installing Hardwood over old/new Concrete Slab Hages Flooring 7 06-04-2008 01:02 PM
built up slab question stampcrete Concrete & Paving 9 03-27-2008 05:24 PM
Demo a foundation under a radiant heat slab without disturbing the slab...? wackman Remodeling 18 04-02-2007 12:38 AM
stone over painted porch Gordo Masonry 5 03-21-2006 10:52 PM
