Tinting(Coloring) The Grout.
Old 10-20-2011, 12:01 PM   #1
Mad Italian
TheItalian204's Avatar
Trade: Licensed Mason/Owner of small business
Rewards Points: 2,004
Send a message via Skype™ to TheItalian204
For the longest time I have been using this method.
Its actually kind of my own recipe
I would like to hear what you guys think and if you have a better method or better mix.
I use 1:1:6 ratio with plasticizing agent and hue added to the mix slowly to achieve color needed.
By 1:1:6 I mean white cement,lime and plaster sand.
What do you guys use?
www.gabesmasonry.ca
Originally Posted by Mud Master View Post
I hate when a profitable job becomes a charitable write off.
TheItalian204 is offline
Old 10-20-2011, 12:26 PM   #2
Tscarborough's Avatar
Rewards Points: 1,402
Re: Tinting(Coloring) The Grout.
I think that is fine, but how could you ever match it?
Tscarborough is offline
Old 10-20-2011, 12:37 PM   #3
Mad Italian
You mean batches?
This requires two of my greatest tools: empty ice-cream pale and measuring cup
Match is almost 95%
Say you mixed 6 mixes and now you need wheel barrow full.
I get an ice-cream pale of lime,ice-cream pale of federal and bucket of sand.
hue comes in 42 OZ boxes..I chop it in 6 OZ in measuring cup and usually that is enough.
Again it depends on what color you need to get,darker/lighter and it takes some calculations.
Took me couple of **** ups until I got it right....
www.gabesmasonry.ca
Old 10-20-2011, 12:40 PM   #4
I assume you are using liquid tint?
Old 10-20-2011, 12:41 PM   #5
Mad Italian
I used to. I switched to dry. Easier to work with.
www.gabesmasonry.ca
Old 10-20-2011, 01:15 PM   #6
Then I would not use volume measurements. I can create a difference of 30-40% by weight using volumetric measurements.
Old 10-20-2011, 07:13 PM   #7
JBM's Avatar
Trade: Masonry
Rewards Points: 4,144
Doesnt everyone buy the little bags that go into 1 batch?
JBM is offline
Old 10-20-2011, 07:20 PM   #8
That is the easiest way, if not the cheapest. The cheapest is to buy a digi scale and once you find your formula, make your own bags.
Old 10-20-2011, 07:22 PM   #9
JBM's Avatar
Trade: Masonry
What is the "street" value for the bags of the secret formula!
JBM is offline
Old 10-20-2011, 08:00 PM   #10
The pre-bagged is 20-30% more than bagging it yourself, so you can figure it from there. We sell about 100 times as much bulk as pre measured, but then with 10 pigments the range of colors is limitless. We can not stock the premixed, there are too many, so they are special order and also involve freight. Pre-mixed masonry cement is also an option, but again, stocking a multitude of colors is not practical, so they also involve lead time and freight.
Urethane Grout Installation Tidbits angus242 Tiling 100 05-13-2013 03:23 PM
grout stains unavoidable? MichaelEmerson Tiling 32 02-27-2011 06:56 AM
Grout sealer Jer Tiling 7 12-19-2010 02:50 PM
best stain-resistant grout for glass tile rock nohow Tiling 3 10-10-2010 05:58 PM
Grout seperation on 2nd floor deck tile9 Tiling 4 08-23-2010 05:57 AM
