Tile Installation Over Exterior Brick Wall
Old 03-17-2009, 06:54 PM   #1
lenbrodsky's Avatar
Trade: general contractor
hey guys
looking for some adwise how we can install ceramic tile over exterior brick walls? is there any prep required?
What tile and mortar should be used for this job?
Never did before Im a framer.
lenbrodsky is offline
Old 03-17-2009, 07:15 PM   #2
Tscarborough's Avatar
Re: Tile Installation Over Exterior Brick Wall
Then don't do it.
Tscarborough is online now
Old 03-17-2009, 07:17 PM   #3
IF, however, you are trying to specify it for bidding purposes, you should specify mechanically attached lath, scratchcoat, and thinset per tile manufacturers recommendation.
Old 03-18-2009, 05:55 AM   #4
cleveman's Avatar
Trade: custom home building
How much wall are you talking about?
Where will you start on the bottom and finish on the top?
Will you stop under a soffit? How deep is the soffit?
How is the condition of the brick, why do you want to cover it?
Where are you located?
cleveman is offline
Tags
tile installation
Grab bars - studs and spec hollow wall anchors jmfrederick Plumbing 5 12-13-2008 01:12 PM
Need to frame a wall over concrete wall. joseph Carpentry 3 10-07-2008 08:19 PM
Major wall frame remodel Jackpine Framing 0 09-03-2008 10:06 AM
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
Bending Schluter stainless Rondec for curved wall Rambo1224 Flooring 1 06-17-2007 08:53 PM
