Thin Brick Underlayment
Old 10-06-2008, 12:27 PM   #1
Youngster
Cache's Avatar
Trade: Builder / Consultant / Designer
Anyone have any suggestion for the underlayment behind an exterior thin brick application? Local code says the minimum required is 2-layers 60 minute paper.
Masons around here usually use a layer of 15# felt, but many people are starting to insist on Tyvec housewrap. It is my understanding that Tyvec wrap is only a vapor barrier and will not serve as a water proofing layer like felt. Obviously, thin brick is water permeable so the waterproofing layer is necessary. Some have suggested doing a layer of Tyvec along with a layer of felt. Seems to me that such an application would sort of defeat the purpose of the Tyvec.
What say the gurus here on CT?
Cache is offline
Old 10-06-2008, 05:51 PM   #2
artisanstone's Avatar
Trade: Stonemasonry
Re: Thin Brick Underlayment
It boils down to whatever the brick supplier recommends. That said, I lean towards Tyvek + tarpaper. As you put your first coats of mud on, the tarpaper absorbs water and swells. When it dries, it leaves a very small void for water drainage behind the paper. This deals with actual water infiltration (rain). Vapor migration from the interior can sometimes be a different story.
artisanstone is online now
Old 10-06-2008, 06:40 PM   #3
Youngster
Cache's Avatar
It turns out that Dupont's Tyvek specs require both Tyvek and then felt. They won't warranty the tyvek if the mortar is in contact with it. So they specify tyvek on sheething, followed by "building paper", then lath/scratch coat etc... for stucco, brick, and rock veneer applications.
Cache is offline
Old 10-06-2008, 08:40 PM   #4
6stringmason's Avatar
Trade: masonry
I always go Tyvek then felt paper.
Kamps Masonry & Concrete Countertop Design Green Bay, WI
920-680-3195
Visit our website @
http://www.concretecountertopsdesign.com/
6stringmason is offline
Old 10-06-2008, 09:06 PM   #5
eekie34's Avatar
Trade: Masonry restoration
then whats the deal with the tyvek stucco wrap?
eekie34 is offline
Old 10-07-2008, 09:58 AM   #6
Youngster
Cache's Avatar
I think you're right. The Tyvek Stuccowrap is allowed to be placed directly in contact with the lath/scratchcoat, but only in locations where the local building codes accepts it as a substitute for two layers of building paper.
Cache is offline
Thin Brick, VS Regular Brick Project53 Construction 25 03-11-2010 03:13 PM
cement wash or concrete rub a thin layer over brick pavers brownstone89 Masonry 14 08-25-2008 07:14 PM
exterior thin brick pointers? lund6771 Masonry 6 01-09-2008 09:21 PM
thin brick floors samiam Flooring 1 10-23-2007 09:36 AM
Robinson Thin Brick CJKarl Masonry 9 10-17-2007 06:26 AM
