Thin Brick Over Painted Concrete
Hey Guys! Been MIA on here for a while...
I'll be installing Robinson Thin Brick over PAINTED sheetrock in a condo. I've done plenty of thin brick, but never over painted sheetrock. Here are my 3 methods that I'm weighing out: Option #1 (BEST): Lathe, scratchcoat, install thinbrick with thinset Option #2 (2nd Best): Install 1/2" CBU over sheetrock, float joints, install thinbrick with thinset. Option #3 (worst, but passable): Sand the crap out of the painted sheetrock, and install thinbrick with modified thinset. Do you guys have any feedback on which one would be best in this application? |
Re: Thin Brick Over Painted Concrete
For thin brick in residential application, sand the ****rock and then trowel on a product such as Parex Base coat 121, then thinset the brick. For commercial work, Either one or 2, but 2 is usually better.
It ain't Rocket Science unless you are building rockets. |
Definitely never heard of that Parex product. Interesting. What purpose does it serve?
Stiffness and adhesion.
Trade: Stonemasonry
On a similar note, one of my contractors wants me to put up a rough textured plaster on interior walls. On a previous project (not by me) they used regular buff mortar mix over lath to get the effect. Is the lath necessary? Should we use blueboard as a substrate? Primer? Glue in the mix?
Bill Baddorf Bill@artisanstoneworks.net www.artisanstoneworks.net www.stonefoundation.org |
There are products out there to achieve that without lathing. LaHabra Plaster Mix is one, but there are others, both cementious and acrylic.
As a rule, you trowel on the base coat over whatever is there, then apply the finish coat, smooth or rough, from Tuscan to Venetian.
| Concrete Company delivered junk concrete. How best to pursue? | marcomjl | Concrete & Paving | 46 | 08-07-2011 02:55 PM |
| 4x4 posts in concrete vs. saddles | Strongarm | Decks & Fencing | 20 | 08-31-2009 10:41 PM |
| Help with concrete bid | KennMacMoragh | Concrete & Paving | 13 | 08-17-2009 04:50 AM |
| Brick "cistern" under concrete floor | jarvis design | Remodeling | 19 | 05-29-2009 11:39 PM |
| something for the masonry department | dakzaag | Masonry | 2 | 05-08-2009 10:23 PM |
