Tearing A Chimney Down
Old 12-16-2008, 12:34 PM   #1
jcalvin's Avatar
Rewards Points: 534
I am having to tear down a chimney and am concerned about the weight of the brick and mortar. I have a gooseneck dump trailer and am trying to figure out if I can dump the weight myself. I done some rough figuring and came up with a rough brick count of 1000 bricks. At a pound and a half per brick, that brings my total up to about 1500lbs. Add a little for the mortar attached and I am up to around 1700lbs.
The chimney is and old one without any kind of flue liner at all. It is maybe 15' tall and something close to 24"x24".
Does my brick count and estimated weight sound about right or am I completly off base?
Cal
You hired WHO
jcalvin is offline
Old 12-16-2008, 12:53 PM   #2
TaitINC's Avatar
Trade: Build, Remodel, Roofing, Siding etc...
Rewards Points: 250
Re: Tearing A Chimney Down
I use this site for a reference http://www.age.psu.edu/extension/factsheets/h/H20.pdf
it shows 4" bricks at 42 pounds per sq ft and cement at 94 pounds per cubic ft
8 bricks per course and 3 courses per foot. 8 sq feet per linear foot of chimney at 346 lbs per linear foot times 15 feet equals 5190 lbs total weight for 2'x2'x15'. my calculation of 346 lbs is done by 42 lbs per square foot and add 10lbs of mortar. a linear foot foot of chimney is 2 sq feet per side times 4 sides equals 8 square ft per linear foot. 8 sq ft times 42 lbs per sq foot plus 10 lbs mortar equals 346 lbs.
this seems a little confusing, but i'm posting it anyway
TaitINC is offline
Old 12-16-2008, 12:53 PM   #3
Tscarborough's Avatar
Rewards Points: 1,392
For 1000 brick plus mortar, I would figure closer to 4000# if not a little more.
Tscarborough is offline
Old 12-16-2008, 01:07 PM   #4
jcalvin's Avatar
Rewards Points: 534
Thanks for the info. Tait, thanks for that listing of weights. Nice thing to hang on to. After looking at that sheet and calculating that, I come up with 5523lbs. Good thing I can dump 11k. It bothered me after seeing the 6x6 pad on the trailer jack about 8" under the ground.
Cal
You hired WHO
jcalvin is offline
Old 12-16-2008, 01:13 PM   #5
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,878
More than one load. Check you brick weight. You malso end up with more mud and junk than you expect.
Just start at the top and drop everything down into the trailer.
Dick
concretemasonry is offline
Old 12-16-2008, 01:18 PM   #6
jcalvin's Avatar
Rewards Points: 534
If it will ever quit raining down here so I could make a trip to the dump, I'll come back and update the total weight. We can even turn it into a game. Lets see who can guess the weight the closest. Winner gets a brick out of the chimney to use as a paper weight, fishing sinker, or a spare key when your customer forgets to hide you the key.
Cal
You hired WHO
jcalvin is offline
Old 12-22-2008, 11:05 AM   #7
jcalvin's Avatar
Rewards Points: 534
OK. I just got back from the landfill and the scales were frozen. After I explained in great detail about their lack of work ethic, they finally agreed to estimate my load so I could pay them and dump it. The guy at the landfill estimated it at 6500lbs. He figured my bill at $55/ton to come up with a total of $68.50. I asked him to refigure and he came up with the same thing again, so I wrote the check and took off before his calculator thawed.
So Tait is the closest, send me your shipping info and I will send you your prize.
Cal
You hired WHO
jcalvin is offline
Dangerous Chimney Dilemna The Boss Masonry 27 04-25-2009 09:35 PM
Chimney problem Jack3185 Masonry 2 04-20-2009 09:28 PM
Masonry chimney on new EPA fireplace? GregWCIL Masonry 8 10-28-2008 09:51 PM
Chimney woes Rich Turley Masonry 4 09-18-2007 08:09 PM
Questions About a No Good Chimney Bruce Masonry 11 01-02-2007 12:46 AM
