Tarring Foundation For Raised Patio...
Old 04-05-2007, 09:21 PM   #1
ruskent's Avatar
Trade: Outdoor D/B
I looked at a raised patio job this week. The patio will be 24inches above grade. I assume it would be best to tar the foundation, correct?
And is it neccessary to tar the foundation if there is no basement?
Matt
ruskent is offline
Old 04-06-2007, 07:37 AM   #2
CR2's Avatar
Trade: Stone,brick,block,concrete,decorative concrete..
Re: Tarring Foundation For Raised Patio...
No, if you have no basement/crawl space you don't have to waterproof the foundation, doing it is better, just to minimize water infiltration and damage, but not needed.
Good Luck!
CR2 is offline
Old 04-06-2007, 08:38 AM   #3
concretemasonry's Avatar
Trade: Masonry consultant
Don't worry.
The black stuff is really not a waterproofer and is a damp proofer. Most also have a short ilfe. I can make a customer feel good.
Dick
concretemasonry is offline
Old 04-06-2007, 11:36 AM   #4
denick's Avatar
Rusk,
Will there still be at least 6" of foundation above the patio height?
Nick
"Every day I remind myself that my inner and outer life are based on the labors of other men, living and dead, and that I must exert myself in order to give in the same measure as I have received and am still receiving" Albert Einstein
denick is online now
Old 04-06-2007, 04:00 PM   #5
ruskent's Avatar
Trade: Outdoor D/B
There will not be any foundation above the patio. The heights do not work out .
Part of the siding will be cut removed, flashing installed, new j channel installed. I just do not know if this will be along the entire length of the patio or just for the stairs. Again i am not sure on the final height yet.
ruskent is offline
Foundation repair (New business) Help! crosshair66 Business 10 05-18-2008 09:19 AM
foundation grade problem snuddenstang Masonry 23 08-20-2007 10:07 AM
Common Patio Door Problems adriand Remodeling 1 01-14-2007 01:27 AM
Patio Expansion andy998 Masonry 6 08-20-2006 06:32 PM
