Trade: carpentry and electrical
Tapering For A Chimney
Hello! I have to say that it's been some many years since I worked on a chimney. I'm building a house and we ran into a question about the chimney that I wasn't sure how to answer. I hope I can make this make sense:
The damper on the chimney is 36 inches but the flu opening is 13 inches; so, we need to taper the chimney from 36 to 13. What is the angle/degree of taper and how high do we need to go with it so that it will be stable? Also, should I put in firebrick above the damper through the taper? Thanks so much for your help!! |
Re: Tapering For A Chimney
It ain't Rocket Science unless you are building rockets. |
Great Info Tscar!
| chimney | roo | Masonry | 6 | 11-28-2007 08:56 PM |
| Chimney woes | Rich Turley | Masonry | 4 | 09-18-2007 08:09 PM |
| Questions About a No Good Chimney | Bruce | Masonry | 11 | 01-02-2007 12:46 AM |
| Chimney & Creosote question | BreyerConstruct | General Discussion | 33 | 12-14-2006 08:02 PM |
| Brick Veneer Chimney w/ Factory Insert | rhomfeld | Carpentry | 6 | 09-15-2006 09:23 PM |
