Supporting Brick While Enlarging A Garage Opening
Old 09-16-2008, 08:07 AM   #1
AtlRemodeling's Avatar
Trade: Residential Remodeling
Rewards Points: 250
I need some help on this one. I have a customer that has a sagging garage door header. Apparently no one calculated a point load on the garage door header from a beam on the second floor. As part of the repairs, the customer wants to enlarge the opening to accommodate an 8' door instead of the existing 7' door.
I have attached a cad of the wall (my camera battery died and gas is too high to drive over just for a picture). Anyway, here my question. Is there anyway to support the brick above the opening while I remove the existing lintel, beam and 1' of brick? The house is 8-10 years old and short of removing brick on the entire side, I do not want it to appeared "patched". We are doing a stucco border around both garage doors when we finish the opening so I have a little bit of leeway for the first 12" of brick surrounding the door.
Thanks in advance for any advice.
Point of clarification: The garage door that is sagging is the double door (16') and we are enlarging the opening from 7' high to 8' high. The beam is undersized and the lintel is warped due to the sagging beam therefore, both will be replaced. I can brace the lintel and remove/replace the beam from inside the garage. Is there anyway to then remove 1' of brick and insert a new lintel?
AtlRemodeling is offline
Old 09-16-2008, 08:33 AM   #2
genecarp's Avatar
Rewards Points: 2,000
Re: Supporting Brick While Enlarging A Garage Opening
both the lintel and header will now be to short, by the time you remove both, the only thing you will have left is sheathing and brick, the brick must go. imo
genecarp is offline
Old 09-16-2008, 09:18 AM   #3
Kaiser's Avatar
Trade: Independent Cost Estimator
Rewards Points: 252
I'm no Mason but I'm thinking the brick should have a Angle Iron lentel above the door now. You will need to replaced it. So a 6' X 4' X 5/16" angle iron run 12" past the R.O. should be plenty to hold up the brick while you do the removal of the brick below. (Of course I'm not an Engineer either so you want to consult the local codes.) Cut the Mortar line out at the new height and slide the new angle iron in before you remove anything.
That's my 2 cents I'm sure some Masons will chime in. Good Luck
"Go confidently in the direction of your dreams. Live the life you have imagined."
Henry David Thoreau
Kaiser is offline
Old 09-16-2008, 10:58 AM   #4
artisanstone's Avatar
Trade: Stonemasonry
Rewards Points: 612
It can be done a number of ways. Heck the house movers move whole chimneys along with the house! It will come down to "is it worth it".
artisanstone is online now
Old 09-16-2008, 12:11 PM   #5
send_it_all's Avatar
Rewards Points: 1,000
I think he raising the height of the door opening...not the width.
send_it_all is offline
Old 09-16-2008, 02:44 PM   #6
bobcaygeonjon's Avatar
Trade: Bricklayer / contractor
Rewards Points: 150
Yes it can be done by knocking out bricks at about 2' intervals, passing a prop with an attachable "foot" through
But honestly it is a lot of work and will always look like a patch job. It really would be easier to take out the Bwk above and re - build. With some carefull toothing and mortar match it will look a lot better.
bobcaygeonjon is offline
Old 09-16-2008, 08:13 PM   #7
wellbuilthome's Avatar
Trade: building for 30 years. new homes , additions
Rewards Points: 250
It is much faster to use a air hammer and remove the brick. You could clean the bricks and put them back up. If the door is not getting wider you mite try to cut in a new header and remove the old header after. If there are lots of brick ties the brick mit hang off the framing. I removed 50 ' of block work on a ranch and left all the brick hanging above . It was nasty but it worked.
wellbuilthome is offline
Old 09-16-2008, 09:53 PM   #8
CJKarl's Avatar
Trade: Masonry
Rewards Points: 3,926
I've also sawed out a long horizontal joint, placed a 3X4 angle in the curf and braced it from below.
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Thin Brick, VS Regular Brick Project53 Construction 25 03-11-2010 02:13 PM
Does fireplace opening in block wall opening need support? Square-One Masonry 6 11-22-2008 01:31 AM
Brick ledge requirements for garage TennesseeBrian Masonry 12 10-17-2007 08:43 PM
Brick Veneer support over large opening. Atlantex Masonry 8 08-13-2007 11:02 PM
Does fireplace opening in block wall opening need support? Square-One Construction 1 02-28-2006 12:59 AM
