Suggestions On Supporting Chimney In Attic?
We have been task to support three chimneys constructed during mid 1800 above ceiling. The brick will be supported by four by six timbers in attic spaced twelve inches on center. Understand the lower chord and rafters are 4" x 6" spaced 12" on center. The chimney will stay above roof line and fastened/supported on top of lower chords. We are providing more floor space for library and offices. The chimney will be viewed from outside strictly for preservation purposes. We brain stormed ideas and will possibly install support pipe down inside interior wall to concrete footer. However, can these timbers support the weight of the brick? Each chimney are approx. 3' x 2' and will be six to seven foot tall. I contemplated sliding 6 x 6 angle iron into mortar joint and strapping brick for support prior to removing lower section of chimney. Give me your ideas. By the way important note, this is in the Florida panhandle and subject to hurricane winds. Yes, we are right on the Gulf of Mexico near Pensacola.
Home Depot aisle walker
Trade: home remodeling
Re: Suggestions On Supporting Chimney In Attic?
I'd say it could be done, steel frame on top of crossbraced posts (a lot of figuring to do) but its a really bad idea. You'd always be waiting for that phone call telling you some bad news.
| The Following User Says Thank You to willworkforbeer For This Useful Post: | John Andrews (06-10-2009) |
Trade: Masonry / architectural stone carving
Have an engineer figure it out and SIGN off on whatever is decided.
JVC |
| The Following 2 Users Say Thank You to jvcstone For This Useful Post: | John Andrews (06-10-2009), naptown CR (06-10-2009) |
mason
Trade: Mason contractor
"brick will be supported by four by six timbers in attic spaced twelve inches on center."
masonry on wood ? dont think its good idea.
http://www.diamondqualitymasonry.com/ |
| The Following User Says Thank You to DQM For This Useful Post: | naptown CR (06-10-2009) |
mason
If the chimneys are not going to be used take them down, frame them up and use thin cut brick
| The Following User Says Thank You to DQM For This Useful Post: | DJ9222 (06-10-2009) |
Trade: masonry
That phone call is gonna come sooner or later! Get rid of the stacks if your not using them and then fake it above the roof. This will also come back to haunt someone down the road and if anyone with a sense of taste and preservation ends up with the house they'll be cursing your name and anyone else involved.
![]() D. |
#7 | |
Re: Suggestions On Supporting Chimney In Attic?Quote:
Offhand I'm not sure it would be allowed. I'm guessing facing or thin brick are not the answer due to the historic nature. I would want metal. A good engineer is much cheaper than a lawsuit. |
| The Following User Says Thank You to tkle For This Useful Post: | naptown CR (06-10-2009) |
| Dangerous Chimney Dilemna | The Boss | Masonry | 27 | 04-25-2009 09:35 PM |
| Metal chimney replacement | trade | Construction | 5 | 04-06-2009 01:35 PM |
| Frost inside the attic? | SOSSW | Roofing | 22 | 04-03-2009 08:26 AM |
| Drying out an attic - advice wanted | HellisLikeNewrk | General Discussion | 5 | 01-22-2009 08:55 PM |
| Recessed light cans, heat and attic insulation | im4snow | Insulation | 3 | 09-30-2008 03:02 PM |
