Styrofoam Under Concrete Slab
Old 03-25-2010, 04:18 PM   #1
randybelk@comca's Avatar
Trade: CONTRACTOR
Rewards Points: 25
Hi all, I have a customer who has asked me to do something that we usually dont do here in east Tn. He wants me to have styrofoam laid down under the basement floor when we pour it. I have asked around locally, but it doesnt seem to be real popular here. I have heard that the slab will most likely have lots of cracks in it.
If I were to do this, I would at least put 1/2 rebar on 16" -2' grid.
What are some concrete finishers experience with this.
Thanks
Randy Belk
Athens, TN
randybelk@comca is offline
Old 03-25-2010, 04:50 PM   #2
genecarp's Avatar
Rewards Points: 2,000
Re: Styrofoam Under Concrete Slab
Putting styrofoam under the slab is fairly common here. If the base is preped and tamped properly, and the correct concrete and wire is used, you will crack no more or less than you would without the foam. use plastic VP under the foam, and you will end up with a nice warm dry slab, GMOD.
genecarp is offline
Old 03-25-2010, 04:55 PM   #3
Agree with Gene,
the prep is the thing.
10-10-6-6 is good for most basements.
The #4 16oc seems a tad much to me.
neolitic is offline
Old 03-25-2010, 09:34 PM   #4
Concrete Mike
CONCRETE MIKE's Avatar
Trade: concrete
Rewards Points: 250
I agree,why rebar? Are you going to drive a tractor trailer on it? If u are going with wire no10 wwm is good,it comes in 5'x150' rolls.
CONCRETE MIKE is offline
Old 03-25-2010, 09:57 PM   #5
Fire up the BBQ
griz's Avatar
Rewards Points: 312
A more common detail I have seen is using extruded foam. Same principle as Styrofoam. This is a very common detail in a commercial freezer. If you are intent on using rebar go with a #3. Although like the others have said wire will work just fine.
griz is offline
Old 03-25-2010, 10:01 PM   #6
Rockmonster's Avatar
Trade: Masonry
Rewards Points: 5,494
Agree with gene here as well....we use 2", it's got that T&G going, we tape it some spots to keep it tight...if the base is nice and level, it is a walk in the park....wwm, run the radiant tubes, and you have a warm, dry, easily heated space....
Rockmonster is offline
The Following User Says Thank You to Rockmonster For This Useful Post:
genecarp (03-26-2010)
Old 03-25-2010, 10:47 PM   #7
BuildersII's Avatar
Trade: General
Rewards Points: 250
We had a really interesting job in an old school converted into a halfway house back when I was working for a drywall company. It was a second floor auditorium with a sloped floor down to a stage where they needed a flat and level concrete floor. Obviously adding all that weight to the floor would cause structural issues and cost a fortune in concrete, so we used a foam filler before having the concrete poured.
The way it worked was we had to survey out the auditorium and figure our finish floor height, and then we sent the numbers to a company that pre-cut all the foam with the proper slope. The thing is that they sent us a bunch of 16" wide foam pieces with a sloped side to be glued to the existing sloped floor, and we installed each row of foam pieces 4" apart. The idea is that the concrete would fill those 4" gaps and act as solid support for the layer of concrete going on top of all the foam.
I just thought it was a pretty ingenious way of saving weight and cost, while giving a solid and durable surface.
BuildersII is offline
Old 03-26-2010, 07:00 AM   #8
Working
Cole82's Avatar
Rewards Points: 2,276
Send a message via AIM to Cole82
Doing it right now. I agree with every thing every body is saying. The only thing different is I use expanding foam on the seams. It really glues everything together and makes it a uniform insulattion value.
Cole
The boss of awesome
Cole82 is offline
Old 03-26-2010, 09:09 AM   #9
stuart45's Avatar
Trade: Brickwork
Rewards Points: 1,010
It's part of our Building Regs to insulate under the floor slab, and round the perimeter as well.
stuart45 is online now
Old 03-26-2010, 10:42 AM   #10
TimNJ's Avatar
Rewards Points: 2,430
I put 4" styrofoam under my slab back in 1992. No cracks or problems.
TimNJ is offline
400$ for a 14X7 concrete slab? Coastal Pros General Discussion 7 12-13-2009 01:00 AM
how much to charge. concrete curb demo. tie new curd to 6" slab Evan03 Construction 12 11-28-2009 12:54 PM
Concrete overlay over existing garage slab daft_GC Concrete & Paving 10 11-19-2009 07:42 AM
site preparation for future concrete slab on clay soil RFTTTE Masonry 8 07-21-2009 09:32 PM
concrete slab on paved drive? durham Concrete & Paving 7 09-13-2008 10:28 PM
