Stucco Repair?
Old 10-28-2007, 07:10 PM   #1
wneumann's Avatar
Trade: carpentry
Angry
Stucco Repair?
AZ new construction residence had soft stucco - less in depth than minimum 3/16 code requirement. New application applied with bonding applied, new 1/4 stucco (with bond agent mixed in), then a rough texture coat. The stucco developed cracks during the cure. Kote Conditioning was applied and then an elastomeric sealer brushed over the cracks with a roller.
SW Duration exterior paint was sprayed on, but the elastomeric lines can be seen.
What is the proper application of the elastomeric to ensure it will not be noticed beneath the paint? I am told that it should have been brushed with a wet paint brush.
What is the best method to repair now?
wneumann is offline
Old 10-28-2007, 07:14 PM   #2
Three Rivers Services LLC
aWorkaHolic's Avatar
Re: Stucco Repair?
Should this not be under warranty?
aWorkaHolic is offline
Old 10-28-2007, 07:19 PM   #3
Tscarborough's Avatar
Re: Stucco Repair?
Bulldoze the house and start over.
Tscarborough is offline
1 coat vs. 3 coat stucco finishing janrickey General Discussion 12 07-17-2011 11:22 AM
Tight Space Stucco Question - Undershot between roof sections CGofMP Construction 3 03-24-2009 09:10 AM
stucco repair rservices General Discussion 1 08-15-2007 10:13 PM
Some questions about painting outside stucco?? Zeebo Painting & Finish Work 10 09-20-2006 08:09 AM
repairing stucco ceilings and cracks Zeebo Painting & Finish Work 10 12-21-2005 06:43 PM
