Stucco Question
Old 04-24-2007, 12:17 AM   #1
jshuatree8's Avatar
Trade: masonry
Stucco Question
can any body educate me on proper stucco intulation and is there a way to lay brick over top of it? say like your bricking a house but two foot under the windows instead of brick stucco the width of the window and then your brick sill over that. i guess thats how u spell sill
jshuatree8 is offline
Old 04-24-2007, 12:51 AM   #2
laybrick's Avatar
Trade: mason contractor
Send a message via AIM to laybrick Send a message via Yahoo to laybrick
Re: Stucco Question
angle iron?
laybrick is offline
Old 04-24-2007, 01:06 AM   #3
jshuatree8's Avatar
Trade: masonry
Re: Stucco Question
der...thanx
Old 04-25-2007, 12:33 AM   #4
laybrick's Avatar
Re: Stucco Question
not tryin' to be sarcastic, kinda wierd worded question.
laybrick is offline
Old 04-25-2007, 10:14 AM   #5
jshuatree8's Avatar
Trade: masonry
Re: Stucco Question
nah notin like that . see around here there is no stucco and no masons doing it. I shoulda thought of that though [the angle iron] ....but what is stucco ...what is it made of ? I would like to bring a more variety around here so future customers can have the opportunity to have a more unique home I've seen it put on on tv but I don't realy know what it consist of. Im thinking it will have to be painted to get that brown or whatever color they might desire. But like I said I know nothing at all about it. I"ve already seen the best way to increase my knowledge is from here.Some of the stuff I've learned from here has set me ahead several years from where I was. I feel more like a professional now. Don't get me wrong I can lay em...but the more knowledge a man has the better mason hes gonna be. thanx for all input. but like I said would love to have info about what to use and how to put it up the right way. thanx again
Old 04-25-2007, 10:19 AM   #6
jshuatree8's Avatar
Trade: masonry
Re: Stucco Question
oh sorry.. its like your house is bricked... but under the window sills the width of your window by about two foot ..instead of brick ...be made with stucco.
Old 04-25-2007, 11:34 AM   #7
stacker's Avatar
Trade: masonry
Re: Stucco Question
stucco is a cement finish.most generally about 3/4 inch thickness applied in three coats.a scratch coat,brown coat,and finish coat.the finish coat can be any texture and cement coloring can be added to the finish coat so you would not have the need to paint it.
stacker is offline
Old 04-25-2007, 09:11 PM   #8
laybrick's Avatar
Re: Stucco Question
type in drivit or synthetic stucco & check out a couple sites
laybrick is offline
Old 04-25-2007, 09:25 PM   #9
Dik Redi's Avatar
Trade: Masonry
Re: Stucco Question
Dont forget the diamond lathe before u do scratch coat,, ( thats your best bet to prevent any seperation of your stucco from the wall your aplying it to for years to come if all coats done right)
Dik Redi is offline
Old 04-25-2007, 10:43 PM   #10
concretemasonry's Avatar
Trade: Masonry consultant
Re: Stucco Question
latbrick - "Type in Dryvit" and expect non-code compliance and law suits on a wood frame structure.
It can be O.K. on a masonry wall if you know what you are doing and the nail bender installs the windows right.
Dick
concretemasonry is offline
Old 04-25-2007, 11:37 PM   #11
Flat and Smooth
Drywall1's Avatar
Trade: Drywall install and finish
Re: Stucco Question
Lawsuits is right! Thats why when approached about Carrara Stucco I went for it. The foam stuff has its place just not over wood. Nate
Krieser Drywall
Krieser Insulation
www.KrieserDrywall.com
Drywall1 is offline
Old 04-26-2007, 10:03 AM   #12
jshuatree8's Avatar
Trade: masonry
Re: Stucco Question
thanx for the info new stucco sounds like what i need so i ordered a brochure.......
1 coat vs. 3 coat stucco finishing janrickey General Discussion 12 07-17-2011 11:22 AM
Tight Space Stucco Question - Undershot between roof sections CGofMP Construction 3 03-24-2009 09:10 AM
Stucco Question RTred Masonry 2 05-29-2007 03:35 PM
Stucco Question Part2 Subia29 Masonry 10 05-06-2007 01:01 AM
Some questions about painting outside stucco?? Zeebo Painting & Finish Work 10 09-20-2006 08:09 AM
