Stucco Patch
Old 03-23-2009, 07:33 AM   #1
NAV's Avatar
Trade: commercial building restoration
Stucco Patch
hey guys, I have a 12 story stucco building in Cleveland where the existing stucco is failing in a few areas (approx 4% of the building). the owner said that they have been using DAP stucco patch.....I dont want to use that product.
Anyone have a stucco material that they would recommend for an environment like Cleveland (lots of freeze thaw)
Thanks in advance for your suggestions.
NAV is offline
Old 03-23-2009, 09:13 AM   #2
Sean
SLSTech's Avatar
Re: Stucco Patch
What is on there now? 3 coat, EIFS, ???
Do you have the experience to match the texture & make it blend in?
My best advice is to remove the bad area's - clean up till it reaches a good solid area & replace with the appropriate system / materials. I would also find someone really experienced in doing this type of work and use them.
SLSTech is offline
Old 03-23-2009, 10:23 AM   #3
gallerytungsten's Avatar
Trade: Design
Re: Stucco Patch
Quickrete has a product called "stucco finish coat" that works and is easy to use. Maybe use a bonding agent underneath.
However, since you mention that it's a 12 story building, your cost to reach the areas to repair is probably going to be more than whatever material you actually use. So SLS' advice about using someone who really knows what they're doing is probably the best bet. You don't want to get 12 stories up in the air more than once.
gallerytungsten is offline
Old 03-24-2009, 11:28 AM   #4
NAV's Avatar
Re: Stucco Patch
we have the equipment and experience to work at heights - did a 30 story building last summer. Stucco is not something that we do every day.
Matching the texture will be an issue but nothing a little trial and error wont fix. The substrate under the stucco is brick. bonding agent is a good idea not sure about Quickrete though - its more of a residential product isnt it?
NAV is offline
Old 03-24-2009, 04:42 PM   #5
NJ Brickie's Avatar
Trade: Bricklayer
Re: Stucco Patch
Some quikcrete products are home owner products. Spec mix is owned by quikcrete which is mainly used in commercial work. Quikcrete makes many quality products.
NJ Brickie is offline
Old 03-27-2009, 11:15 PM   #6
ctscontractor's Avatar
Trade: exterior, stucco
Re: Stucco Patch
why won't u use dryvit? Just go to any dryvit dealer and they will help you match the color. The reason for peeling off is temperature they applied stucco in or the buckets left outside in low temp. post some picks, i might help some more
ctscontractor is offline
Old 03-27-2009, 11:42 PM   #7
Tscarborough's Avatar
Re: Stucco Patch
If you could post a pic of a chunk of the failing stucco showing the layers it would help. Is it lath over brick, foam over brick or simply mortar slathered over it. Pretty hard to diagnose without more information.
Tscarborough is offline
Old 03-30-2009, 07:38 AM   #8
NAV's Avatar
Re: Stucco Patch
Well, the stucco is not dryvet its a stucco over block. I contacted BASF and it is a spray on stucco. I am still waiting on material pricing and data pages for the material - I will post the product once i get that info.
We have the equipment that can spray this material so it well be much easier to match now. here is a pic of the building.
Stucco patch-westlake-condo-pictures-001.jpg   Stucco patch-westlake-condo-pictures-014.jpg
NAV is offline
Old 03-30-2009, 04:23 PM   #9
NAV's Avatar
Re: Stucco Patch
OK - the materials i am going with on this project are as follows:
Spot Prime with Thoro CM Primer
Stucco Repair with Thorocoat Heavy Tex
Top coat with VIP 8100 elasto.
NAV is offline
Old 05-26-2009, 03:41 PM   #10
NAV's Avatar
Re: Stucco Patch
Just did a sample of the Thorocoat Heavy Tex in our shop. Not even close
I am going to try STO FreeForm 299 if they ever call me back with a material price.
I don't want to use a cement based product - I dont have time for it to cure. We gotta get this building painted.
Any other recommendations on materials?
NAV is offline
Knockdown Texture Patch - Flashing? mseneker Drywall 7 05-18-2009 12:47 PM
New stucco meeting up with old MichaelNY Masonry 3 11-13-2008 07:25 AM
Stucco patch help Mwcop1 Masonry 2 03-15-2008 02:03 PM
Stucco patch, how much to do EIFS patches? sniperninjafox Painting & Finish Work 7 09-26-2007 08:41 PM
Stucco patch CEM2 General Discussion 5 03-23-2006 04:24 PM
