Stucco Over Painted Block
Old 06-03-2012, 04:32 PM   #1
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
I've got a customer who's home has about three feet of painted concrete block expossed. They asked me about stuccoing it.
I believe it is latex paint.
I've done a fair bit of parging and two coat stucco. The question is what would I need to do to be able to go over the paint?
There isn't enough room for wire mesh or cement board. And I'm not scarifying all that block.
Thanks for any ideas.
ps. The jobs out in the sticks, so there's no chance to sub it out.
katoman is offline
Old 06-03-2012, 04:40 PM   #2
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,168
Re: Stucco Over Painted Block
I'm not a stucco person but I've never seen it done without the mesh. Why isn't there enough room? Stucco can flake and peal easy, I wouldn't consider taking any shortcuts.
kenparsonscontracting.com
KennMacMoragh is offline
Old 06-03-2012, 05:00 PM   #3
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Could you use synthetic after a good power wash of course?
CrpntrFrk is offline
Old 06-03-2012, 05:01 PM   #4
katoman's Avatar
Trade: carpenter
There's existing wood siding above that I'd rather not project beyond.
I've used a two coat stucco that works great on clean concrete/block surfaces. It will not flake off.
I suppose the crux of it is how do I prep the paint for this application?
It may be that I can't. There may be a primer that I can put over the paint so the succo will stick.
katoman is offline
Old 06-03-2012, 05:02 PM   #5
katoman's Avatar
Trade: carpenter
Synthetic what? Stucco?
katoman is offline
Old 06-03-2012, 05:05 PM   #6
CrpntrFrk's Avatar
Yes. PAREX or the like.
Old 06-03-2012, 05:09 PM   #7
katoman's Avatar
Trade: carpenter
I'm fairly sure the stuff I use is like that. Made by Durex. I'll check with them. They may have some type of primer that I can apply first.
Thanks guys.
katoman is offline
Old 06-03-2012, 05:15 PM   #8
CrpntrFrk's Avatar
That is what I suggest.
We have gone over painted surfaces after a good power wash with conventional stucco and it has done fine. I'm talk'n power wash till the paint is almost transparent. Then we add a good stucco glue to the mix.
The synthetic base coat (IMO) will stick to anything and would be the best for your application.
The Following User Says Thank You to CrpntrFrk For This Useful Post:
katoman (06-03-2012)
Old 06-03-2012, 05:21 PM   #9
Tscarborough's Avatar
Rewards Points: 1,402
Total Wall makes a product specifically for this application they say. I have not used it yet, so I can not vouch for it, but if so it would be a very good thing.
Tscarborough is offline
Old 06-03-2012, 05:24 PM   #10
Mad Italian
TheItalian204's Avatar
Trade: Licensed Mason/Owner of small business
Rewards Points: 2,004
grind the pain,wet the block,roll weld-crete on,scratch over the top, then brown and finish or just brown and sponge float.
www.gabesmasonry.ca
Originally Posted by Mud Master View Post
I hate when a profitable job becomes a charitable write off.
TheItalian204 is offline
The Following User Says Thank You to TheItalian204 For This Useful Post:
Red Adobe (06-03-2012)
Old 06-03-2012, 05:55 PM   #11
FYI, this is synthetic stucco.
This happens all the time in some restaurant's that I maintain. Give it maybe five years and it will start chipping, and this is indoors, no weather abuse.
The Following User Says Thank You to KennMacMoragh For This Useful Post:
Old 06-03-2012, 06:07 PM   #12
Mad Italian
I am not entirely sure about what type of EIFS systems get installed around there and I am not knowledge able enough (in comparison to my foreman) to speculate as to why, but its 3rd summer I am getting acquited to it and being certified installer for Akrilon, we offer up to 40 years of warranty on workmanship as well as material.
9/10 EIFS systems WILL fail within 5 years due to poor workmanship.
In scenario with your picture it could very well mean that during application of base coat,it was floated with water which is a big no-no on synthethics.
www.gabesmasonry.ca
The Following 3 Users Say Thank You to TheItalian204 For This Useful Post:
CrpntrFrk (06-03-2012), KennMacMoragh (06-03-2012), Red Adobe (06-03-2012)
Old 06-03-2012, 06:09 PM   #13
CrpntrFrk's Avatar
Sorry but we have done countless entire homes with synthetic stucco. No problems.
Could be the installer I guess.
Old 06-03-2012, 07:04 PM   #14
fjn's Avatar
Trade: mason
Rewards Points: 8,852
I feel a sure bet would be to sand blast off the paint ,apply weld crete,stucco as normal. I would sleep well after that type of prep.
fjn is offline
Old 06-03-2012, 07:39 PM   #15
That would be a mechanically induced failure, i.e. something beat the **** out of it. That is not a good place for a synthetic stucco, it does not have the impact resistance required for a high duty application inside a restaurant.
The Following User Says Thank You to Tscarborough For This Useful Post:
Old 06-03-2012, 08:58 PM   #16
Red Adobe's Avatar
Trade: Metal Roofs, Sparky , Remodels and beer specialist
Rewards Points: 92
EIFS is a good product , it has some limitations of course
As for going over block:
A good cleaning with TSP, brush, and water
A bonding agent (whatever system you choose should have a recomendation)
Fiberglass EIFS mesh and brown coat
Eifs Finish of choice
Dry-vit is what I would check out, complete thickness will be apx 1/4 to 3/8 inch if done right
Red Adobe is offline
Old 06-03-2012, 09:35 PM   #17
JBM's Avatar
Trade: Masonry
Rewards Points: 4,168
Get a 4" grinder and have at it, stucco over it and call it a day.
JBM is offline
Old 06-03-2012, 09:54 PM   #18
Mad Italian
I know where you coming from,but when I was certifying company with Akrilon,they demonstrated that bullet can't pierce through right application.
Nevermind conventional stucco that if done properly and cured for right amount of time can withstand as much as 2500 PSI.
www.gabesmasonry.ca
Old 06-03-2012, 10:28 PM   #19
Yeah, I went to a jobsite with a Thoro rep back in the day, a jobsite that had complaints about impact damage. He grabbed a hammer off a wandering carpenter and said, "Watch this!", and buried the F'ing hammer to the hilt in his "impact resistant hard coat system". The warranty cost on that WWTP cost him his job and Thoro lost our million pound plus a year business.
TheItalian204 (06-03-2012)
Old 06-04-2012, 01:00 AM   #20
CanCritter's Avatar
Trade: bricklayer/stonemason
Rewards Points: 342
would try to powerwash it with a good system and see how it turned out to start and then would grind where nesassary..wet block...roll,brush weldbond,browncoat.topcoat and float then dash
all in all sandblasting would be easyest and quickest but would be the most expensive and messyest mind you your gona have paint flakes everywhere anyway eitherway
CanCritter is offline
1 coat vs. 3 coat stucco finishing janrickey General Discussion 12 07-17-2011 10:22 AM
applying rock venner to painted stucco JackH22 Masonry 4 03-07-2011 02:13 PM
Stucco over CMU question CJKarl Masonry 24 04-16-2010 02:23 AM
block work rebar question paintbob7 Masonry 4 05-31-2009 10:46 AM
window return in concrete block house bmancanfly Remodeling 10 05-15-2009 03:30 AM
