Stucco Over Concrete???
Old 04-22-2012, 07:25 PM   #1
tonyvlx's Avatar
Trade: Drywall Finishing
Rewards Points: 25
Id like to stucco the 3 ft concrete foundation walls in my garage. What is the proper procedure to do this right? Im a drywall finisher by trade so i know how to use a trowel. Any tips would be appreciated. thanks
tonyvlx is offline
Old 04-22-2012, 07:37 PM   #2
fjn's Avatar
Trade: mason
Rewards Points: 8,852
Re: Stucco Over Concrete???
Roll on a coat of LARSONS PLASTER WELD,two 3/8 coats of PAREX 210 stucco,two coats of their elastomeric coating (in color you choose)
fjn is offline
Old 04-22-2012, 07:48 PM   #3
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Where are you located?
Here in AZ sponge or spray the wall to dampen. Then we use some one coat with fiber. In fact the lumber yard here sells premixed and if you have that available then I would suggest that to you. Try to apply to achieve 3/8" thickness. Let dry a bit then using a damp sponge float, sponge in a swirl motion. After this has cured to the touch, spray lightly with water every few hours for about 24 hours. This allows for slower cure time so it will not crack.
After that you could use synthetic stucco finish coat, color coat or if it looks good leave it or paint it.
Once again this is in a desert climate here in Arizona. You need to know what mother nature does to certain stucco and certain applications in your area to make to correct choice!
Good luck!!
CrpntrFrk is offline
Old 04-22-2012, 08:17 PM   #4
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 18,123
We alway's put a bonding agent on the block, before applying the stucco finsh.
Sir Mixalot is offline
The Following 2 Users Say Thank You to Sir Mixalot For This Useful Post:
CrpntrFrk (04-22-2012), fjn (04-22-2012)
Old 04-22-2012, 09:19 PM   #5
CrpntrFrk's Avatar
That's always a good idea!
Old 04-22-2012, 10:48 PM   #6
Mad Italian
TheItalian204's Avatar
Trade: Licensed Mason/Owner of small business
Rewards Points: 2,004
water---->weld-crete/weld-bond---->pop-corn dash...
or
water--->weld-crete/weld-bond---->scratch---->sponge----->skip trowel
Good Luck
Gabe.
www.gabesmasonry.ca
Originally Posted by Mud Master View Post
I hate when a profitable job becomes a charitable write off.
TheItalian204 is offline
Cement backer board over concrete slab gtimk4 Flooring 14 12-21-2010 08:46 AM
Staining concrete in ready mix truck jduck777 Concrete & Paving 10 12-07-2010 10:13 PM
Concrete slab prep, level and tile Tkelly Tiling 2 11-20-2010 11:27 PM
poured concrete pier with pre-cast concrete grade beam arthurganem Architecture & Design 6 10-06-2010 03:28 PM
Concrete with Fly Ash vs. Concrete without? cdkyle Concrete & Paving 19 07-28-2010 09:57 PM
