Stucco Finish Coat Seperating From Base Coat?
Old 08-17-2007, 11:59 AM   #1
mwcuff's Avatar
Trade: Construction Consulting
Hi,
I let a subcontract to install stucco on a new home in southwest New Mexico. The paper, wire, and gray coat were inspected prior to the finish coat being applied. The temps varied from 60 to 110 Deg F during installation.
The finish coat around the window and door openings is now seperating from
the base (gray) coat after about one year.
What went wrong and how is the problem corrected?
Your help will be greatly appreciated!
mwcuff is offline
Old 08-17-2007, 01:40 PM   #2
Tscarborough's Avatar
Re: Stucco Finish Coat Seperating From Base Coat?
It sounds like a one-coat system with a synthetic finish?
Tscarborough is online now
Old 08-17-2007, 01:52 PM   #3
Thom
thom's Avatar
could be a couple things.
The gray coat could have been poorly mixed, to much sand/to little cement, remixed after it started to set, ... In other words, the material has failed.
The gray coat could have improperly cured. It needs to be wet down several times after application prior to doing the color coat. If it dries but does not cure it will not hold up. On my jobs I do this. The stucco guys don't come back to "cure" it, that's left to me the contractor. Every day, twice a day if it's really hot, I will hose the entire exterior down really well. Should do it for about a week. This allows the stucco to cure.
So, if the problem is one of the above, what you have is a failure of the first coat. The color coat has nothing to bond to.
I don't understand what "Construction Consulting" is. Are you a contractor?
thom is offline
Old 08-18-2007, 10:20 AM   #4
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
Someone with experence hired to manage a project for The owner. Hires and watches subs , so mistakes don't happen.
Driftwood is offline
Old 08-18-2007, 07:54 PM   #5
mwcuff's Avatar
Hi Thom,
Thanks for the reply. I was a Project Super / Manager for Electrical / Mechanical Contractors on Heavy Construction Projects. Power Plants, Steel Mills, Oil Refineries, etc. A few Office Buildings and Malls also.
Started consulting after retiring to NM in 1998.
The corrective action on the Stucco sounds like the work must be re-done?
mwcuff is offline
Old 08-18-2007, 07:58 PM   #6
mwcuff's Avatar
Hi Thom,
Thank you for the reply.
I was a Project Super/ Manager for Electrical / Mechanical Contractors.
Power Houses, Steel Mills, Oil Refineries, Office Buildings, Malls.
It sounds like the Stucco must be removed and re-done?
mwcuff is offline
Old 08-16-2008, 07:55 PM   #7
SM
smeyer's Avatar
Trade: Commercial Inspector
Originally Posted by mwcuff View Post
Hi,
No sealant or backer rod around those fenestrations. Sounds like no sill pans or proper wrapping. Water is getting in there. You should have an IR scan of your walls for water intrusion.
sm
smeyer is offline
Old 08-16-2008, 08:39 PM   #8
stuccoman's Avatar
Trade: Ex-Stucco contractor
Has the stucco been painted?
Do you have a picture?
If it was your house wouldn't you want it done right?
stuccoman is offline
Old 08-16-2008, 08:41 PM   #9
This is an old post. He had crappy one coat without proper flashing and the acrylic finish cracked off under the swelling particle boardaround the windows.
Old 08-16-2008, 08:42 PM   #10
stuccoman's Avatar
Thank you.
1 coat vs. 3 coat stucco finishing janrickey General Discussion 12 07-17-2011 11:22 AM
New stucco finish eager2start Masonry 9 03-23-2009 04:59 PM
New stucco finish eager2start Construction 4 03-23-2009 04:16 PM
new skim coat over old stucco 415moto Construction 6 07-12-2006 08:28 PM
Stucco Wall Finish plazaman Masonry 5 03-21-2006 10:44 PM
