Trade: CONCRETE
Stucco Corner Bead To Concrete Blocks
We have not done this before...only onto wood. We are trying to install the stucco corner beading to block walls with no luck. The nails don't seem to want to go through and into the blocks. Does anyone have any input on a way that would be easier?? Thanks
Sommers Concrete Pumping, INC |
Trade: Masonry
Re: Stucco Corner Bead To Concrete Blocks
I used them on a STO job. I just glued them up with stucco.
Trade: Ex-Stucco contractor
Stubbyconcrete nails,light loads in a ramset, T-Nailer.
If it was your house wouldn't you want it done right? |
Trade: Masonry Restoration and Construction Company based in Nashville, Tn
I don't know alot about stucco work but I use 1/2" Ramset power point nails from Home Depot and a 3lb hammer to drive metal wall ties on to block. I would try and nail into the mortar (bed) joints if the block are unfilled on the corners. If that dosn't work you could drill it and use a short drive in masonry anchor like red head or simpson strong-tie.
| Tags |
stucco corner beading ![]() |
| Stucco Corner Bead Staining | sue | Concrete & Paving | 0 | 07-16-2008 10:20 AM |
| Stucco Corner Bead Staining | sue | Introductions | 2 | 07-15-2008 01:49 PM |
| corner bead on densShield | wopachop | Drywall | 32 | 03-27-2008 08:21 PM |
| attach corner bead to fascia | robo | Drywall | 2 | 10-04-2007 09:01 AM |
