justjeff
Trade: Journeyman Carpenter - B3
Stucco On Block
I have a customer that has a block house with stucco applied, then paint. At several areas, all hit by sprinklers, the stucco is failing and it now has the consistency of drywall dust. It and the paint are coming off. We are located in Phoenix so the extreme heat may be a factor. I am a handyman. I know that there are those on this site that acquaint that with dreg but some folks need a deck and a new toilet. Actually, I have a B3 and I am a carpenter. Can a mason give me a line on how I might address this problem so that I can warranty the quality work for a decent period of time?
Left to my own, I would get the dead mud off, prime or seal the block, re-apply the stucco (cement glue needed?), prime or seal again then paint. any suggestions as to why it is happenign in the first place...other than a feller used drywall mud for stucco? thanx, jeff |
Re: Stucco On Block
Make sure the sprinkler does not hit the wall. Other than that you have it, just make sure there is no paint on the repair areas.
It ain't Rocket Science unless you are building rockets. |
Drywall & Painting Pro
Trade: Hang, Finish, Texture, Paint, and Repair.
Re: Stucco On Block
Definitely use a bonding agent before re-stuccoing.
justjeff
Re: Stucco On Block
Okay, I cannot find a local licensed contractor that wants to take on such a small job so I am going to give it my best shot. I will knock off all the old stucco and scarify the surface. Next I will spray the areas down withe muriatic acid in a garden sprayer, then I will apply cement glus directly to the area to be patched and apply nes stucco. After that I will roller-apply a primer that I can really work into the surface and re-paint. That should do it for another 4 years huh?
Trade: Masonry
Re: Stucco On Block
Just my opinion. I don't do a lot of stucco. But I do use acrylic bonding agents. I find that any acrylic bonding agent mixed with a portland cement or a portland based mortar mix do not hold up well to any exterior masonry materials that are expose to a lot of water.
Re: Stucco On Block
CJKarl, there are 2 types of bonding agents. One type will re-emulsify once, the other multiple times. For vertical above grade applications, either will work fine. For below grade and water contact, only the former will work. Check your label.
Trade: Masonry
Re: Stucco On Block
In my opinion the labels are vague. I've seen break down of the bed when the acrylic is rated for exterior.
The problem I see is when it's used in a bluestone over concrete application. Just about ANY paving system is going to let water in. In my opinion in a real world situation. Do not use bonding agents when laying masonry over a slab. |
Re: Stucco On Block
They are vauge, which is all the more reason to be sure. The simplest way is to ask if it is OK for swimming pools. If it is, then it is GTG for anything.
Trade: Masonry
Re: Stucco On Block
Yes it's a bit of a cross thread. But my gut feeling is acrylic admixtures belong inside. I will not use them on exterior applications.
There is no reason that traditional masonry products will not hold up if used correctly. Do you think that by using admixtures your stucco is going to last over 100 years? Portland based stuccos do. |
Re: Stucco On Block
There's no need for the acid. You're better off without it.
Normally there is no need for the glue. In this case it will secure any loose particles from the scarifying. Not much will help with the sprinklers except regular repainting. A coat of cement based waterproofing might work. Last edited by tkle; 03-22-2008 at 12:59 PM. |
| 1 coat vs. 3 coat stucco finishing | janrickey | General Discussion | 12 | 07-17-2011 11:22 AM |
| Tight Space Stucco Question - Undershot between roof sections | CGofMP | Construction | 3 | 03-24-2009 09:10 AM |
| Cinder Block walls, block filler and a leak...question | SeanATL | Painting & Finish Work | 9 | 03-09-2009 04:33 PM |
| Does fireplace opening in block wall opening need support? | Square-One | Masonry | 6 | 11-22-2008 02:31 AM |
| Does fireplace opening in block wall opening need support? | Square-One | Construction | 1 | 02-28-2006 01:59 AM |
