Straightening A Block Wall
Old 12-27-2009, 01:59 PM   #1
mart4005's Avatar
Trade: concrete leveling
Rewards Points: 81
I've got a 20' tall block wall on a commercial building that is buckling outward. What's the best way to straighten this thing? If I leave it as it is, fill cores every three feet or so will it be okay? thanks
mart4005 is offline
Old 12-27-2009, 03:11 PM   #2
CJKarl's Avatar
Trade: Masonry
Rewards Points: 3,926
Re: Straightening A Block Wall
Are you serious? Tear the f-ing thing down before some one gets killed.
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Old 12-27-2009, 04:16 PM   #3
mart4005's Avatar
Rewards Points: 81
Oh, come on, it's only buckling out not more than an inch. Surely there's a solution other than replacing it. That would be seriously major.
mart4005 is offline
Old 12-27-2009, 04:34 PM   #4
Tscarborough's Avatar
Rewards Points: 1,406
First you need to figure out WHY it is buckling, then you need to solve that problem, THEN you need to worry about repair/stabilization.
Tscarborough is offline
Old 12-27-2009, 04:41 PM   #5
mart4005's Avatar
Rewards Points: 81
train tracks across the drive?
mart4005 is offline
Old 12-27-2009, 04:42 PM   #6
Doubtful.
Old 12-27-2009, 04:51 PM   #7
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,914
Is the wall loadbearing or is it just infill between columns and under beams?
A deflection or bowing adds to the bending moment and causes more movement. Since it has bowed that much, it has technically "failed" and is not as strong as when it was built. It will take some forece to bring it back to closer than original construction. Grout by itself does not help much, especially compared to rebar and grout.
It could also be from some humanly applied loads, like mistakes, unanticipated hanging loads or even bumping. In commercial building many strange things happen.
As TS said, there is certainly a cause and you have to determine that to come up with a repair and then corrective action.
Dick
concretemasonry is offline
Old 12-27-2009, 04:58 PM   #8
mart4005's Avatar
Rewards Points: 81
I can easily get rebar in from the top. it is load bearing.
mart4005 is offline
Old 12-27-2009, 05:08 PM   #9
Get it plumb and straight before you build a reinforced wall or you just create a more permanent curved wall with lower strength.
Do you have any idea of the cause of the bowing? If not hire an engineer., since it holding up a lot of weight and resisting a lot of wind/suction.
Dick
Old 12-27-2009, 05:09 PM   #10
Kent Whitten's Avatar
Rewards Points: 2,040
You need an engineer to come look at this. Right now.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 12-27-2009, 05:11 PM   #11
mart4005's Avatar
Rewards Points: 81
When I do figure out the cause of it bowing, what should I do to straighten it?
mart4005 is offline
Old 12-27-2009, 05:21 PM   #12
rselectric1's Avatar
Rewards Points: 584
See quote by framerman
rselectric1 is online now
Old 12-27-2009, 05:28 PM   #13
mart4005's Avatar
Rewards Points: 81
Hey, I didn't think most contractors liked working with engineers!
mart4005 is offline
Old 12-27-2009, 05:35 PM   #14
That would be architects.
You don't seem to be taking the advice so I will say it again.
You need an engineer to look at this. Structural design is not your field of work. Get someone qualified who knows what they are doing with structural engineering to come look at it and design the proper fix.
The Following 6 Users Say Thank You to Kent Whitten For This Useful Post:
carolinahandyma (12-27-2009), DJ9222 (12-28-2009), jimmyw (01-09-2010), mart4005 (12-27-2009), rselectric1 (12-27-2009), tgeb (12-27-2009)
EPDM sheet along BSMT wall grade, under mulch: Cheap fix or disaster? HereNow Excavation & Site Work 4 11-22-2009 08:59 PM
Block wall under existing roof/ceiling... StPete727 Masonry 38 07-12-2009 07:57 PM
Natural Stone Veneer over Painted CINDER Block Tommy C Masonry 14 04-22-2009 11:46 AM
removing a retaining wall Cache Excavation & Site Work 30 07-16-2008 04:57 PM
Backyard office, retaining, and privacy wall Team Scream Masonry 8 08-02-2007 10:27 PM
