Pimp
Trade: General Building
Stone Over Brick Exterior
When applying stone veneer over brick (exterior of the home) can you simply scratch coat and go?? I know with block if it's been painted, sealed, etc we have covered in tyvex, then mesh, scratch coat, then stone.
This brick is clean/untreated in any way - what about cement board over the brick before the stone? thanks for the help |
Chief outhouse engineer
Trade: mason
Re: Stone Over Brick Exterior
If the brick is not painted or treated then you can stick the stone directly to it. You could screw wire mesh on if you wanted to be absolutely sure, but it would be overkill.
D K & Sons The maintenance schedule for brick 1. Stand back and say "man that looks nice!" 2. Repeat as often as needed. |
| The Following User Says Thank You to dakzaag For This Useful Post: | RenovatorsWV (02-14-2012) |
Trade: masonry
So long as the brick is sound nothing else is necessary.
Trade: Stonemasonry
Like the others said..no paint,sealer or bad brick. I'm doing a remodel on a fireplace right now that had horrible stonework that was stuck to the old brick. They used wire lath and anchored it to the brick. It was tough getting it off...if your stone is thin then a mechanical bond will be a good idea.
Think about using a acrylic additive to your scratch coat too. |
Struggling Artist
Trade: masonry/hardscaping
Re: Stone Over Brick Exterior![]() D. |
Aureli Construction
pressure wash before then go for it.
www.aureliconstruction.com |
Trade: Mason
Personally I would bid it for anchoring lath. But I tend to overkill things.
Yeah, it's overwhelming, but what else can we do. Get jobs in offices, and wake up for the morning commute. |
Trade: Masonry
Take the brick down and do a 4" stone veneer imo. It will look fudged around the doors and windows.
Trade: siding
i heard you had to lick it before you stick it
Tom |
| The Following User Says Thank You to Tom Struble For This Useful Post: | JBM (02-15-2012) |
Trade: Mason
Good point, for some reason in my head I was thinking of of a structural brick building.
#11 | |
Struggling Artist
Re: Stone Over Brick ExteriorQuote:
Brick mold and a good job should take the fudge off the doors and windows. JMO, D. |
Mad Italian
Man why would anybody want lick and stick over brick
![]() anyway you can definetly get away with it...appearantly masonry subtrades require only scratch coat over the top. As above mentioned gentlemen,I would pressure wash,check for abscence of some DIY sealer,paint and point the loose joints if those exist. Check manufacturer guide not to void the warranty if "stone" is man made. If you budgeted, for peace of your mind use wire lath.. And use wire lath if its natural stone...its heavier and you dont want to take chances. Last edited by TheItalian204; 02-15-2012 at 06:15 PM. |
The warranty on faux stone simply says the stone will not spontaneously crumble to dust within xx years.
There is Birth then there is Death. In between there is maintenance -Tom Robbins |
#14 | |
Trade: Mason
#15 | |
Mad Italian
As matter of fact I can probably dissolve a piece of cultured stone in glass of cola overnight(ok,maybe over two) But does that mean that OP has to void customer's warranty? |
Any issue he will have will not be covered by the warranty. They do not warrant that the stones will adhere, they do not warrant anything to do with water penetration, they do not, in fact, warrant anything other than the piece of concrete will remain a piece of concrete.
Manufacturers installation instructions are good and should be followed for the conditions under which they provide them. Just do not think that doing so provides any type of warranty.
#17 | |
Mad Italian
I happened to have several accounts with some cultured stone vendors around Winnipeg and I do install on fairly big scale for them,maybe thats why. Either way..you gonna try that trick with glass of coke and piece of concrete?
#18 |
Mad Italian
And btw I am still wondering what "stone veneer" OP is talking about...clarification on whether he is talking about cultured stone or natural stone would be appreciated.
Plus I didnt know tyvek is appropriate for installation any sorts of masonry...even fake ones. |
#19 |
Good thinset manufacturers will warranty pop-off, but if it comes from the stone manufacturer, you better read the small print.
| The Following User Says Thank You to Tscarborough For This Useful Post: | TheItalian204 (02-15-2012) |
#20 |
"I did several installation where companies actually warrantied work/material and would provide free re-installation and material if those failed"
Sorry, but you are mistaken if you think a manufacturer is going to warrant your work. Even if you are a certified installer, they will not guarantee your work.
| Tying new block work into old stone walls | crome | Masonry | 4 | 08-14-2011 04:07 PM |
| Eldorado Stone Over Existing Brick | Aircooled | Masonry | 20 | 03-27-2011 09:44 PM |
| Cultured Stone over Existing Brick Fireplace | fakie99 | Masonry | 7 | 12-01-2008 05:10 PM |
| ICF brick ledge | coupe33 | General Discussion | 7 | 11-29-2008 12:45 AM |
| Face Stone on Exterior of House | rwhittaker | Construction | 2 | 04-20-2007 04:09 PM |
