Stone Foundation Scratch Coat??
Old 05-18-2008, 08:47 PM   #1
EAE's Avatar
Trade: Remodels, Additions, Improvements
This is a change order on a church basement remodel I've been plugging away at.
Walls in the men's room were rotten - so I demo'd to the stone foundation wall. The church-goers love it and want me to "fill in the big cracks with mortar or something and then paint it (the stone) white."
I've done my fair share of tuck pointing and tile work... but
Any suggestions on what to use to 'fill the cracks'?
I'm planning on using UGLI masonry sealer for the 'paint' and I understand that I need to start with a clean dry surface.
Thanks,
Chris
EAE is offline
Old 05-18-2008, 09:03 PM   #2
mdshunk's Avatar
Re: Stone Foundation Scratch Coat??
You are famaliar with how a wall like you describe aspirates, aren't you? You start "sealing" a stone foundation built with lime mortar and you can cause a whole boatload of problems.
mdshunk is offline
Old 05-18-2008, 09:36 PM   #3
Tscarborough's Avatar
Look at the Big Brain on Sparky! S!
Tscarborough is online now
Old 05-18-2008, 09:39 PM   #4
EAE's Avatar
It will be a corner wall approx 5 ft by 12 ft and 7 ft high.
Can this be done?
EAE is offline
Old 05-18-2008, 09:40 PM   #5
mdshunk's Avatar
No, not really. My area has about ga-zillions of stone foundations, and I've seen the problems hacks can cause. You've talked a little bit about it before, if I'm not mistaken, havn't you?
mdshunk is offline
Old 05-18-2008, 10:06 PM   #6
Just a little.
EAE, first confirm that it is lime mortar. If it is light in color and soft, but not loose, then it is probably lime. If it was built before 1910, then it is almost certainly lime. You will have to use a lime mortar to repair it, and then let it breathe, i.e. not put a sealer over it.
If there are other issues causing liquid water to enter the wall, those need to be addressed first.
Old 05-18-2008, 10:58 PM   #7
EAE's Avatar
I don't think it's lime mortar. Called the contact for the church and he says the basement was dug out around 1950 -- replacing a crawl space. The mortar is dark and hard.
The seeping problem is being corrected by the landscape crew --I hope.
Provided it isn't lime mortar, is it possible to clean up this section? Any form of patch and paint/sealant will be better than re-framing it and letting it rot for another 60 years.
Thanks,
Chris
EAE is offline
Old 05-18-2008, 11:00 PM   #8
EAE's Avatar
He could be mistaken though. -- would stone be used instead of block in the 50's?
EAE is offline
Old 05-18-2008, 11:28 PM   #9
Stone is used today. It probably isn't lime mortar, in which case you can tuck it with regular bagged mortar mix, then seal it. Just be sure they fix the problem before you treat the symptoms.
Old 05-19-2008, 07:36 AM   #10
EAE's Avatar
Thank You.
EAE is offline
Old 05-19-2008, 11:07 AM   #11
Tommy C's Avatar
Trade: Mason
Send a message via AIM to Tommy C
Hey Tscarborough, I have a related question. Would it be problematic to apply an adheered veneer with regular mortar over a brick house (built in 1850's) that most likely has lime mortar on the original brick joints?
Tommy C is offline
Old 05-19-2008, 02:22 PM   #12
It shouldn't be a problem, so long as the mortar is sound. How many wythes of brick?
Old 05-19-2008, 05:54 PM   #13
Tommy C's Avatar
Trade: Mason
Not sure how many wythes, but definitely multi wythe. Also, there are some hairline structural cracks due to settlement. In fact the entire rowhouse leans to the backyard slightly.
Tommy C is offline
Old 05-19-2008, 09:10 PM   #14
Wait until the hottest, dryest time of the year to do it, and expect any moving cracks to mirror through. It doesn't sound as though lathing it is worth it, although that is the proper solution.
Old 05-20-2008, 10:03 AM   #15
Tommy C's Avatar
Trade: Mason
Thanks for the feedback, Tscarborough. This is a historically protected district, so there will be a LOT of red tape to go through on this one.
Tommy C is offline
Drainage problems w/98 yr old stone foundation OCRS Landscaping 7 05-19-2008 01:52 PM
Stone Foundation Scratch Coat... EAE Masonry 0 05-18-2008 08:44 PM
Insulating hand laid stone foundation woodisgood General Discussion 2 03-06-2008 09:35 AM
need help with cultured stone scratch coat johnny bravo Masonry 4 12-20-2007 03:23 PM
Venting through a stone foundation MinConst Remodeling 6 12-07-2005 10:34 PM
