Stone Fireplace Facelift..before And After
Old 05-21-2012, 08:31 PM   #1
stonecutter's Avatar
Trade: Stonemasonry
Rewards Points: 2,344
I got a call while in CT last year to take a look at this fireplace because the HO wanted the hearth fixed. When I came back a few months later, this is what I saw...
Before.....
This was installed over nice antique brick with lath and ( I'm guessing ) spec-mix. No stone was thicker than 1.5"....the biggest mortar joint was close to 3.5" wide!
The son-in-law thought this mess looked great...the HO's were not around during the install...the home was being remodeled before they moved down from the northwest corner of SC. They told me they were sick about how this came out.
www.thewoodfiredenthusiast.com
stonecutter is offline
Old 05-21-2012, 08:35 PM   #2
sitdwnandhngon's Avatar
Trade: Mason
Rewards Points: 1,650
Re: Stone Fireplace Facelift..before And After
The before pics didn't show up.
But more importantly.....how much did they have to pay for that thing?
Yeah, it's overwhelming, but what else can we do.
Get jobs in offices, and wake up for the morning commute.
sitdwnandhngon is offline
Old 05-21-2012, 08:46 PM   #3
Trade: Stonemasonry
I told them there was nothing I could do to the hearth that would make a difference...they needed to leave it or rebuild. We are not in stone country around here and the few places that have building stone have extremely limited stock. What this yard had is fieldstone from Tennessee which was split in two and it only had one flat face...though I was able to split certain ones in two myself. Sizes were limited too...I had mostly small stone to work with so I had to make due with what they had.
They let me lay it up how I wanted after I discussed a couple different options with them. I took inspiration from Machu Picchu and for those that get Stonexus, the Japanese dry stone walls in the magazine. Both places have notching and it's something I haven't done before. I blended that style with something I do often...scribing stone to each other and letting the lines flow. I didn't want the look to be linear but more free form. The concrete hearth is the same one from the pressed concrete thread.
Old 05-21-2012, 08:47 PM   #4
Trade: Stonemasonry
No? I can see them.
Old 05-21-2012, 08:50 PM   #5
Trade: Stonemasonry
After
I recycled the old mantle..it is 3" solid cedar. I had a paint store scan a piece of the concrete hearth and painted the mantle. The lighter color was intentional.
The Following 6 Users Say Thank You to stonecutter For This Useful Post:
DavidC (05-21-2012), lukachuki (05-21-2012), pinwheel (08-23-2013), Resta (05-21-2012), superseal (05-21-2012), Tscarborough (05-21-2012)
Old 05-21-2012, 08:50 PM   #6
Tscarborough's Avatar
Rewards Points: 1,392
There we go. Yes it is improved by 1000%.
Tscarborough is offline
The Following User Says Thank You to Tscarborough For This Useful Post:
stonecutter (05-21-2012)
Old 05-21-2012, 08:56 PM   #7
Trade: Stonemasonry
Close ups....
The Following 3 Users Say Thank You to stonecutter For This Useful Post:
DavidC (05-21-2012), Fundi (05-21-2012), lukachuki (05-21-2012)
Old 05-21-2012, 08:59 PM   #8
Man, that is a lot of cutting. Did you scribe and cut or scribe and let someone else cut?
Old 05-21-2012, 09:02 PM   #9
Trade: Stonemasonry
Two fiddy
Old 05-21-2012, 09:04 PM   #10
Trade: Stonemasonry
No..I did everything myself. Believe it or not I did more chiseling than cutting...but it was still tons of cutting.
I forgot to mention..this veneer is 3"-6" and I used a 3:1 mortar type S.......yes, I used ties.
Old 05-21-2012, 09:22 PM   #11
tgeb's Avatar
Rewards Points: 412
That looks Fabulous! What did you do to the fire box, paint it also?....it went from brick to black.
Again, a spectacular job!
www.gebcon.com
tgeb is online now
The Following User Says Thank You to tgeb For This Useful Post:
Old 05-21-2012, 09:34 PM   #12
Trade: Stonemasonry
Yes I did.It was something my first boss did often and I used high heat spray paint.
They don't plan to use the fireplace believe it or not.
Old 05-21-2012, 10:16 PM   #13
JBM's Avatar
Trade: Masonry
Rewards Points: 3,500
That's real nice, I like the color of the stones. Are they just fieldstone?
JBM is online now
The Following User Says Thank You to JBM For This Useful Post:
Old 05-21-2012, 10:18 PM   #14
JBM's Avatar
Trade: Masonry
Btw I love the thin stone on the other pics.someone must have had a real good idea that day, and to put wire on the bricks too, priceless....
JBM is online now
Old 05-21-2012, 10:25 PM   #15
Trade: Stonemasonry
Yes. I have worked with this stone a couple times now and it's got a wide variety of color...mostly buff tones, some rose, orange, brown, etc. The hardness varies too..some stones were soft like certain types of limestone or sandstone and others were hard like basalt.
Old 05-21-2012, 10:30 PM   #16
lukachuki's Avatar
Rewards Points: 1,002
Every stone installed with TLC
Looks Great...really great!!!
I'm a little mean, but I make up for it by bein' real healthy. Earnest T. Bass
lukachuki is offline
The Following User Says Thank You to lukachuki For This Useful Post:
Old 05-21-2012, 10:38 PM   #17
Renaissance Man
superseal's Avatar
Rewards Points: 4,956
That job is worth more to the trained eye than that of it's counterpart...particulary being 3"/6 veneer with that fancy hearth.
Owner must be very pleased as I would expect
superseal is offline
The Following User Says Thank You to superseal For This Useful Post:
Old 05-21-2012, 10:40 PM   #18
Trade: Stonemasonry
Here are some demo shots just for you then. I was told they did this wonderful job in two days.
They let me have the brick and I saved all but a few....they may get new life in my next WFO ( not in the dome ). The mortar was lime/sand.
Stone fireplace facelift..before and after-bfp-demo.jpg   Stone fireplace facelift..before and after-bfp-demo2.jpg   Stone fireplace facelift..before and after-bfp-demo-3.jpg   Stone fireplace facelift..before and after-bfp-demo-6.jpg
Old 05-21-2012, 10:44 PM   #19
JBM's Avatar
Trade: Masonry
What a mess.
JBM is online now
Old 05-21-2012, 10:47 PM   #20
Trade: Stonemasonry
What a mess.
54 pails of rubble to be exact..that doesn't count the thin stone ( which they wanted ) and all the brick.
Before & After, #2 pgriz Roofing Picture Post 12 02-09-2009 11:00 PM
