Stihl Concrete Cut Off Saw Question
Old 08-24-2008, 07:20 PM   #1
plazaman's Avatar
Im looking to purchase a Stihl cut off saw, probably a used unit off of ebay, how reliable are these units? Should I looking into other brands?
Question, will the 14" blade be enough to cut into sidewalk slabs and curbs? Or is the 16 necessary?
Thanks
plazaman is offline
Old 08-24-2008, 07:29 PM   #2
CJKarl's Avatar
Trade: Masonry
Re: Stihl Concrete Cut Off Saw Question
14" is a good all around size. I wouldn't buy one used though. I've burned through one a year for the last 8 years. The best one I've used is a Multiquip...and I will be buying another Multiquip when this one craps out.
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Old 08-24-2008, 07:52 PM   #3
General Contractor
Snow Man's Avatar
Trade: Construction Management
you mean a demo saw? nice choice, very reliable.
ear muffs ,dust mask and safety glasses not incl..
DECOSnowRemoval&IceControl
Serving Delaware County & Philadelphia Pa
610 457-9721
Snow Man is offline
Old 08-24-2008, 08:03 PM   #4
Kgmz's Avatar
We have a Stihl TS350 and have had it for about 10 years now. It still works great and has been very reliable, in fact just used it Friday to cut some 12" ductile iron pipe. And will be using it Monday with the Cutquik Cart to cut some pavement.
Kgmz is offline
Old 08-24-2008, 08:15 PM   #5
Tscarborough's Avatar
A 14" will cut 4", but no more.
Tscarborough is offline
Old 08-24-2008, 08:20 PM   #6
raskolnikov's Avatar
Trade: masonry
I had 2 Partner saws and rued the day I bought them! I finally threw them away and now I have a Stihl and 2 Makitas and like them both, the Stihl seems to have more balls but I like the balance of the Makita. I would spend my money on either again.
D.
raskolnikov is offline
Old 08-24-2008, 09:58 PM   #7
plazaman's Avatar
i really dont want to buy new, its 1 of those things you use 3 times in 5 years. i have to make a couple of cuts now and thats it.
i also notice parts seem to be easy to come by with the stihls, rebuild kits. etc...
plazaman is offline
Old 08-24-2008, 10:07 PM   #8
Trade: masonry
Hey plazaman,
Buy youself a blade and just rent if your talking such little use.
D.
Old 08-24-2008, 10:19 PM   #9
TimelessQuality's Avatar
Trade: GC/Remodeling
I got a really tight ts350 off ebay a couple years ago. I asked about compression and starting before I bid. Guess I was lucky
-Steve
"The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein
TimelessQuality is offline
Old 08-24-2008, 10:21 PM   #10
Yep, buy the blade, rent the saw if you only use it a couple times a year (just don't forget to take your blade off when you or your guys return it).
Old 08-24-2008, 10:37 PM   #11
wellbuilthome's Avatar
Trade: building for 30 years. new homes , additions
lI have two stihl a 12 & 14 we use the 12 most of the time. Most slabs are 4" or 5 " even if the blade dosent cut all the way thru you can bust the last 1" or so , curbs I cut from the top and front and break the back. The 16" blades cost much more then the 12. I had a 14" for about 20 years and it walked.
wellbuilthome is offline
Old 08-25-2008, 09:05 AM   #12
6stringmason's Avatar
Trade: masonry
I've had a stihl ts400 for about 3 years now. The same saw! IT works great. Still idles perfectly after it warms up for a minute. And its called a nazi saw around here.
Kamps Masonry & Concrete Countertop Design Green Bay, WI
920-680-3195
Visit our website @
http://www.concretecountertopsdesign.com/
6stringmason is offline
Old 09-04-2008, 08:59 PM   #13
plazaman's Avatar
how do you guys start the stihl? i got mines today, pour mixed gas and it wont start, cleaned the plug still. choked and set on start postion, kept on pulling, no go.
plazaman is offline
Old 09-04-2008, 09:07 PM   #14
Handle It!
MALCO.New.York's Avatar
Prime 5 times. Choke on...NO THROTTLE.Crank 5- 7 times. Choke off. Crank again with NO THROTTLE. Should pretend to start. Throttle and crank.
Be sure that the Mix Ratio is 50:1.
If this method fails, check spark.
Ultimate Wisdom---------
MALCO.New.York is offline
Old 09-04-2008, 09:23 PM   #15
Trade: masonry
plazaman,
Used!!!?
D.
Old 09-04-2008, 09:26 PM   #16
The_Game's Avatar
Trade: Contractor for fema (disaster recovery division)
Send a message via AIM to The_Game
The first time the saw is really dry.
take the spark plug out poor about 10 drop of gas in it and the saw should start up at the first pull.
The_Game is offline
Old 09-04-2008, 09:44 PM   #17
Trade: masonry
He's right on the 1st time out!
D.
Unless it's used!
Old 09-04-2008, 11:11 PM   #18
plazaman's Avatar
yes its used. but it really doesnt look that bad at all. im pretty sure i'll get it going by tomorrow, thanks guys, i'll let you know.
plazaman is offline
Old 09-05-2008, 10:30 AM   #19
Kgmz's Avatar
Ours Stihl has always started on at least the second pull.
First make sure you have spark. Then make sure you are not flooding it. do you smell gas when you are trying to start it?
Then make sure the air cleaners are clean. There will be 2 of then a outer and a inner.
And last if it still won't start and you don't really smell gas out of the exhaust. And if it was sitting for a long time unused, then the carb is probably gunked up and need to be cleaned.
Kgmz is offline
Old 09-05-2008, 07:18 PM   #20
plazaman's Avatar
got it to work today!, my guy cut a slab with it, works great! nice machine, i have a hilti blade on it
plazaman is offline
Hardwood to concrete floor, with nothing in between?? SBI Flooring 7 08-01-2008 02:21 PM
Ready Mix Concrete Question highpeaks Masonry 27 07-31-2008 02:21 AM
Sewer Infrastructure Question ABLE1 Excavation & Site Work 20 05-28-2008 11:05 AM
Mortar Bedding for Stone on Concrete Question. lukachuki Masonry 10 05-26-2007 10:09 PM
Question regarding concrete roofing tiles. Oregon_Rob Roofing 3 01-16-2006 09:58 AM
