Split Cultured Stone
Old 06-07-2005, 12:27 PM   #1
6stringmason's Avatar
Trade: masonry
Anyone have any idea what would make cultured split down the middle. I did a chimney and when the home owner went to nail the cap on he said he used 8 pennies and each corner split right down the middle. all the stones all the way down. I've never seen or heard of anything like that and was wonder what some of you thought. I'm going to go take some pics in a few days when I've got some time and I will post them.
6stringmason is online now
Old 06-07-2005, 12:37 PM   #2
bergenbldr's Avatar
Trade: builder remodelor
Re: Split Cultured Stone
Is this a wood framed chimmey,sounds like a framing problem,also is there a foundation under chimney or is this a cantilevered platform.
bergenbldr is offline
Old 06-07-2005, 04:13 PM   #3
lukachuki's Avatar
All I can say is ouch! I'd like to see some pics.
Tim
lukachuki is offline
Old 06-07-2005, 05:44 PM   #4
Trade: masonry
Ok here is a pic of the chimney. It is a wood framed chimney with no support under other than the general framing. Meaning its a not a full masonry chimney. It is for a gas fireplace so there is just the normal 10" I think it was pipe for exhaust. Here is a picture before he put the cap on. I will post the other pics of the broken stone when I get time to get out there. Probably a day or two.
Old 06-09-2005, 06:24 PM   #5
Trade: masonry
Ok guys. Here are the pictures I took this morning of the split stone. It wasnt pretty. Any guesses you have would be appreciated as I've never seen this since I've been doing this type of work. The owner said it happened when he was nailing the cap on with 8 pennies. He said it only did it to 3 corners and when I went up there he said now the 4th corner is doing it. Only hairline on the 4th though. This chimney is not even 1 yr old. I just want to make sure its not something I did wrong and to figure out what happened to help him get this taken car of. Thanks in advance for the help. And yes I know the stone are dirty but we didnt clean and seal them to I could get there to look at this and replace them.
Old 06-09-2005, 09:16 PM   #6
bergenbldr's Avatar
Still think has to do with a lack of proper framing support. I assume lath was nailed /wraped around corners. Either that or chimney installer was beating on inside with hammer.
Old 06-09-2005, 10:50 PM   #7
jvcstone's Avatar
Trade: Masonry / architectural stone carving
appears to me that there has been some expansion of the underlayment. Is it possible that any moisture got in behind the stone?? Saw some real rock columns wrapped around cedar 4x4 split like that. The mason had not wrapped the cedar with felt paper, and back filled all of the void space. . What puzzels me is that it happened when the home owner nailed down the cap. Got to ask the obvious. Did he try to nail into the cultured stone? Some of that stuff doesn't have any strength to speak of. Or was that when it was first noticed, but had split earlier?
Your going to have to do some forensic investigation on this one.
JVC
John VanCamp
www.jvcstoneworks.com
jvcstone is offline
Old 06-09-2005, 10:59 PM   #8
bergenbldr's Avatar
Wonder if this might be due to edge swelling of osb. Most cultured stone ive seen is installed over plywood not osb .
Old 06-09-2005, 11:19 PM   #9
Teetorbilt's Avatar
I'm with jvc and bergen on the framing expansion. The stones may have already been in tension and the nails just gave the stones the start that they needed, like cutting a diamond.
The nailing of the cap and the cracks may also be unrelated, just coincidence. All corners doing the same thing goes back to the substrate.
Albert Einstein
Teetorbilt is offline
Old 06-09-2005, 11:36 PM   #10
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
If it was me I would be contacting the cultured stone manufacturer and quizing them.
Mike Finley is offline
Old 06-10-2005, 08:05 AM   #11
Trade: masonry
Ok thanks for the help and suggestions guys. When I found out what happened I will let you know.
Old 06-10-2005, 02:29 PM   #12
Trade: masonry
Well I brought these pics to the dealer that sold the stone. He said he's seen this many times. It's due to movement of the wood frame most of the time. Since masonry is a solid piece that has no give it cracks when the wood framing "dries up" or if it twists even an 1/8". Also when the wire mesh isnt wrapped around corners properly this can happen but I always overlap about 2-3 inches. Quite possibly the owner did it too when he hopped up there to nail in the 3/4" osb cap before the tin got put on.
One more possibility is the difference in extreme temperature in the cavity during winter when fireplace is on.
Old 06-10-2005, 07:02 PM   #13
bergenbldr's Avatar
Might also want to check if rafters were doubled under chimney,similar to skylight framing.
Old 06-11-2005, 06:23 PM   #14
bergenbldr's Avatar
In looking at the pics i noticed cap only extends flush to face of stone ,not 1to2 inches past face called for by owens corning instructions.Probaly not cause of spliting but may cause problem in future.
Cultured Stone rockbrain Masonry 38 08-12-2009 10:54 AM
cultured stone prices samiam Masonry 9 08-13-2007 05:13 PM
Looking for Cultured Stone work in NJ HemiMan2500HD Help Wanted or Looking For Work 2 03-20-2007 06:58 PM
Cultured Stone mant Masonry 35 09-12-2006 07:46 AM
How to remove cement from cultured stone? ruskent Masonry 9 01-31-2006 04:07 PM
