Smoke Shelf
Old 02-18-2010, 10:02 PM   #1
Burns-Built's Avatar
Trade: Residential Construction & Masonry
Rewards Points: 430
Smoke Shelf
How many guys use a smoke shelf?
How many think you don't need a smoke shelf?
Some guys use them because thats just how its done but does a smoke shelf really function other than just taking the downdraft and spinning it to keep it from blowing your fire all over the floor?
How about Round liners vs. Square i know thats a hot topic, although most places don't even stock round liners, but the physics of a round liner just makes sense.
Give me your 02 .
There will always be a market for quality.
Burns-Built is offline
Old 02-18-2010, 10:19 PM   #2
lukachuki's Avatar
Rewards Points: 1,002
Re: Smoke Shelf
yes
I'm a little mean, but I make up for it by bein' real healthy. Earnest T. Bass
lukachuki is offline
Old 02-18-2010, 10:27 PM   #3
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
Rewards Points: 786
Re: Smoke Shelf
Yes to a smoke shelf. Makes a downdraft bounce back up if constructed properly.
No to the round flu pipe, illegal in some areas. Illinois is one state they are not legal I have been told. Not sure why except for old drainage tile was clay and fired, maybe not the same process as chimney flu therefore more likely to fail?
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline
Old 02-18-2010, 10:31 PM   #4
Mason
brickstretcher's Avatar
Trade: Bricklayer
Rewards Points: 25
Re: Smoke Shelf
brickstretcher is offline
Old 02-18-2010, 10:34 PM   #5
CanCritter's Avatar
Trade: bricklayer/stonemason
Rewards Points: 342
Re: Smoke Shelf
yes...smoke shelf is a integral part of the firebox
CanCritter is offline
Old 02-18-2010, 10:54 PM   #6
Nouveau Eccentric
Diamond D.'s Avatar
Trade: masonry/hardscaping
Rewards Points: 2,534
Re: Smoke Shelf
Yes, i use. Yes, you need. Smoke does swirl, but i use square, though they do sell round, 'round here.
" ROCK YOUR WORLD "
fb
Diamond D. is offline
Old 02-19-2010, 03:44 AM   #7
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 602
Re: Smoke Shelf
Yes to smoke shelf...we use both round and square flue tiles depending on configuration. Have also used Industrial stainless steel flue for masonry fireboxes on occasion
bytor is offline
Old 02-19-2010, 07:27 AM   #8
AmeliaP's Avatar
Trade: Masonry
Rewards Points: 1,624
Re: Smoke Shelf
yes to smoke shelf - we are doing a repair right now to add one that was not installed. HO can't light the fireplace without filling the house with smoke. There are a few other issues as well.
AmeliaP is offline
Old 02-19-2010, 09:39 PM   #9
Rockmonster's Avatar
Trade: Masonry
Rewards Points: 5,494
Re: Smoke Shelf
Absolutely yes to a smokeshelf....whenever I get asked to look at a smokey fireplace, I know what I will usually find...1) the damper is too low, sometimes AT the height of the opening...2) no, or almost no smokeshelf...3)undersized, or choked off flues..4) too short a stack...Every now and then it will be none of the above, but these cover almost all problematic fireplaces.....I did a job in a small CT town where the building inspector insisted that he not see daylight looking up the fireplace opening. Now of course the only way to do that is to have a smokeshelf about 12-16" deep...I thought it was an odd requirement, one that is nearly impossible to do with 99% of your average set of blueprints....but I have never seen a whisp of smoke from any fireplace that has that deep a shelf, so count me in as a firm believer...also yes to round flues, I use those quite a bit lately, but they seem more a regional choice, west, southwest. With picky inspectors, they help as well, as you can usually go 1/12 of the fireplace opening as opposed to 1/10 with square or rectangular....I like em.....
Rockmonster is offline
Old 02-19-2010, 09:45 PM   #10
solar guy
naptown CR's Avatar
Trade: solar contracting
Rewards Points: 1,000
Re: Smoke Shelf
yes to shelf
naptown CR is offline
Old 02-19-2010, 10:54 PM   #11
wazez's Avatar
Trade: masonry
Rewards Points: 766
Re: Smoke Shelf
I say yes to the round flue liners. Most of the chimneys we build today are built with round Chimtek liners. When smoke goes up a chimney it don't turn corners it swirls around.
wazez is online now
Old 02-20-2010, 08:33 AM   #12
jvcstone's Avatar
Trade: Masonry / architectural stone carving
Rewards Points: 250
Re: Smoke Shelf
Smoke shelf---never build a fireplace without one
Been a while since I've shopped, but never recall seeing round flue liners in Austin--Maybe Tscar can bring me up to date as to what's available.
JVC
John VanCamp
www.jvcstoneworks.com
jvcstone is offline
Old 02-20-2010, 09:24 AM   #13
Rocha_Const's Avatar
Trade: Masonry and Stone Work
Rewards Points: 25
Re: Smoke Shelf
We have always used one for every fireplace.
Rocha_Const is offline
Simplex Smoke Detector ABLE1 Low Voltage 12 01-07-2010 10:25 AM
Cleaning of smoke damage Tahoe Painter Painting & Finish Work 16 01-01-2010 04:07 PM
smoke walls naptown CR Commercial Construction 18 09-11-2009 05:29 PM
smoke detector chirping woodworkbykirk Electrical 7 03-24-2009 07:51 AM
Can't put the smoke back in. Careless? maybe.. poor design? definitely! Electric_Light Low Voltage 2 01-11-2009 03:01 AM
