Trade: Landscape contractor
Small Problem
Installed a fieldstone driveway last year. As you can see by the photos channel drains were installed between the stone driveway and the aggregate driveway. The architect and the GC decided to put a mortar joint between the channel drain and the concrete. It is now cracking apart.
Strangely it seems to be flaking off on the top 1/2" of the joint. I am not surprised it is breaking up. We are in NC and it is hot during the summer. I am sure the concrete is expanding and contributing to the mortar joint failure. Also, a lot of traffic and water. Anyway, the question is do I grind it out and replace it with mortar again. Or replace it with colored caulk. The caulk will stand out a bit i'm sure but seems like the best solution. What type of caulk should I use? Other suggestions welcome. Thanks, Mike |
Re: Small Problem
another photo
Re: Small Problem
Caulk for sure.
Pretty driveway. What kind of stone is that, a natural veneer? Isn't it a bumpy ride? |
Re: Small Problem
Thanks for the reply. I have not used much caulk. Is their a specific type for this application?
Thanks for the compliment. The stone is 3" -4" fieldstone. My guess is, it is from Tennessee. And yes it is a bit of a bumpy ride. We probably culled about 30% of the stone we purchased. They wanted an "old world look" and this is what they chose. It's really not that bumpy, at least I'm confident it is going to hold up. I would not be confident using flagstone on such a driveway. It's laid on 8" of concrete, plus mortar bed, plus stone. Mike |
Re: Small Problem
Ive had good results with
PL concrete and masonry caulk. I'd cut out as much of the old as possible and use a backer rod before the caulk, create the expansion joint that probably should have been there to begin with.
Trade: masonry
Re: Small Problem
i agree with neo.do away with as much cement in that joint as possible.it should have never been put in to begin with.
life is short,do your masonry naked!! http://ok.local.yahoo.biz/knabemasonry/index.html |
Re: Small Problem
Once you put the caulk in, while it's still wet, sprinkle a sand/gravel mix on top. It may blend in with the agg drive and not be so noticable.
Re: Small Problem
Hey natural1, just curious...why so thick of a concrete slab? I'd think 5-6" of reinforced concrete would be sufficient, no? Especially in Carolina.
Re: Small Problem
Thanks for all the replies - caulk it is. I guess the single reason for such a thick slab is the homeowners are super wealthy and can afford it. Was not my call to pour the slab that thick. I guess it doesn't hurt.
I believe this house which was a renovation of a house built in 1900 cost about 8 million to build. It is in a historic area of Chapel hill. This is one of 5 houses they own. Be glad to share some photos of all the stone work we did. Mike |
| 5'x5' Walk-In Master Closet too small? | kdub1777 | General Discussion | 7 | 06-25-2007 10:37 PM |
| Small Mig or Tig welder | BlenderWizard | Tools & Equipment | 17 | 05-17-2007 10:42 PM |
| small vacuums | mdshunk | Tools & Equipment | 18 | 04-09-2007 09:28 PM |
| Need help moving a lot of small rocks.... | metomeya | Landscaping | 7 | 03-29-2007 07:32 PM |
| Ideas on very small air compressor | IHI | Tools & Equipment | 13 | 02-03-2006 05:51 PM |
