Slate Scratches
Old 09-16-2006, 05:29 PM   #1
Plays Well With Numbers
Debookkeeper's Avatar
Trade: Manager retail wood residential building materials
Slate Scratches
Hi guys. I have a sofa table exactly like the one in this link, and a few of the slate tiles have some surface scratches on them (they are white in color). Are there any methods to removing scratches from slate -(other than to get rid of the children) like a way to buff them out? Thanks in advance for the help!
http://www.strictlysouthwestern.com/..._html/sofa.htm
Debookkeeper is offline
Old 09-16-2006, 05:49 PM   #2
Tscarborough's Avatar
Rewards Points: 1,388
Re: Slate Scratches
A black/brown crayon?
Tscarborough is online now
Old 09-16-2006, 05:54 PM   #3
mdshunk's Avatar
Rewards Points: 2,002
Re: Slate Scratches
A couple of drops of mineral oil or lemon oil on a cotten rag will make them vanish. You'll need to do the entire surface so that it will all blend in. NOT oily... just a couple of drops on the rag... well, maybe 1/2 a teaspoon, but the rag should be virtually dry.
mdshunk is offline
Old 09-16-2006, 05:56 PM   #4
Re: Slate Scratches
Is that your professional opinion?? Besides, it won't match
Old 09-16-2006, 06:08 PM   #5
jvcstone's Avatar
Trade: Masonry / architectural stone carving
Rewards Points: 250
Re: Slate Scratches
I'd try the mineral oil also. Or use a color enhanser type sealer. Tom's suggestion is not too far off base--a lot of countertop fabricators use majic markers to hide scratches on dark colored stone.
JVC
John VanCamp
www.jvcstoneworks.com
jvcstone is offline
Old 09-16-2006, 07:02 PM   #6
reveivl's Avatar
Trade: Renovations
Rewards Points: 1,000
Re: Slate Scratches
If you can get, and keep, slate wet, then scratches vanish... so, use the oil, or perhaps a sealer if the surface is already sealed. Rich.
reveivl is offline
Old 09-16-2006, 07:13 PM   #7
Re: Slate Scratches
I tried the lemon oil. Thanks - it did "erase" some of the minor scratches, and I am pretty positive there is a sealant on the slate already. What kind of sealant do they use?
Old 09-16-2006, 07:33 PM   #8
Re: Slate Scratches
Oh, you didn't say it already had a sealant. Just reseal it and the scratches will disappear. I use crayons and Sharpies to fix scratches and dings in all kinds of stuff.
Plastic slate roofing dougchips Roofing 20 04-12-2007 08:52 AM
Ungaged Slate Flooring CJKarl Masonry 0 03-01-2007 08:13 AM
Slate Repair-Installation-Looking for Winter work ron kugel Help Wanted or Looking For Work 5 10-25-2006 09:47 AM
Slate Tile for Outside Patio? ridgeline_dev Flooring 6 08-20-2006 09:51 PM
Granite or Slate ron schenker Flooring 6 07-19-2006 06:20 PM
