Which Size Angle Grinder For Cinderblock Joints? - Masonry - Contractor Talk
Old 03-05-2018, 08:30 PM   #1
johnishere's Avatar
Trade: Finish Construction
Arrow
Hey Folk,
I normally do finish carpentry. That said, I will need to remove some joints from cinderblock in basement (to remortar). Which size angle grinder would be best? Will a 4.5" work, or will I need a 6"?
Seems like a 4.5" may not be able to get very deep into the joints (what, like about 1"?)
[I have a 9" angle grinder. But that thing would be cumbersome since it's bigger and heavier - especially doing the vertical joints - even with a 7" blade on it.]
Thanks much.
johnishere is offline
Old 03-05-2018, 09:02 PM   #2
General Contractor
greg24k's Avatar
Rewards Points: 7,516
Re: Which Size Angle Grinder For Cinderblock Joints?
4.5 will work with a tuck-point-blade. If you have something like this like the image below that would be the ideal for that, better joint depth control and it's much easier to make a nice straight cut.
greg24k is offline
Old 03-05-2018, 09:42 PM   #3
Renaissance Man
superseal's Avatar
Rewards Points: 5,586
I use the 5" bosch tuck pointer with the sandwich blade...not a blade on the market that can compete with it in terms of quality and longevity.
Which Size Angle Grinder for Cinderblock Joints?-burns-project-343a.jpg   Which Size Angle Grinder for Cinderblock Joints?-img_2545a.jpg
supersealconstruction.com
superseal is online now
The Following User Says Thank You to superseal For This Useful Post:
greg24k (03-05-2018)
Old 03-06-2018, 05:33 AM   #4
johnishere's Avatar
Cool. Thanks for the feedback guys. Since these are cinderblock and not brick, the vertical joints aren't as much of a problem (since they're not as short). Even still, I remembered that, a 4.5" makes it easier to get into the mortar joint vert/horizontal intersections.
Bosch sandwich blade looks like the way to go.
Old 03-06-2018, 07:53 AM   #5
JBM's Avatar
Trade: Masonry
Rewards Points: 5,432
Your not going to want to sink the grinder into the head joints, just cut em like a half inch.
JBM is offline
Old 03-06-2018, 10:54 AM   #6
fjn's Avatar
Trade: mason
Rewards Points: 9,560
Oh yeah,you will change your mind quickly after you use a Latux Triple Stack Supreme.
https://www.google.com/search?q=Latu...6w_Ud-bFeWDgM:
fjn is offline
Old 03-10-2018, 03:27 AM   #7
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 6,855
I'd use the 9" grinder as until you get tired, it will naturally cut faster with the added power, and control the greater hand spacing gives you.
Sometimes a chipping hammer, air or electric can out perform a grinder, especially on block that were dirty prior to being laid.
The most important thing is keeping the dust out your lungs and eyes, and off the 5.00$ of garage sale garage items in the basement, Don't forget to charge for moving anything each and every time....
If you can get the HO to let go of some the barnacles of his/her life, the job will go faster.
Don't grind out all the joints in one area at one time, unless you need the practice free underpinning.
Fouthgeneration is offline
Old 03-10-2018, 10:57 PM   #8
tjbnwi's Avatar
Rewards Points: 4,928
Arbortech AS 170.
tjbnwi is offline
Old 03-11-2018, 11:14 AM   #9
fjn's Avatar
Trade: mason
Originally Posted by tjbnwi View Post
Arbortech AS 170.
Good tool for lime mortar. With OPC mortar,it will shake your teeth out and not cut.
fjn is offline
Old 03-11-2018, 02:28 PM   #10
Windycity's Avatar
Trade: Masonry
Rewards Points: 6,194
You only need to grind out an inch so whatever grinder fits a 4 inch blade. Most of my guys prefer small (cheap) lightweight grinders since they are easy to hold, but bigger dedicated tuckpointing grinders are heavier and have a lot more power. This one is my go to grinder because I like the dust collection system on it.
Windycity is online now
The Following User Says Thank You to Windycity For This Useful Post:
fjn (03-11-2018)
Old 03-22-2018, 08:45 PM   #11
JBM's Avatar
Trade: Masonry
JBM is offline
Metabo W24-180 7" angle grinder vs Ridgid 7" twist handle? fishnaked Tools & Equipment 2 11-18-2017 10:49 PM
Need new 4.5" Angle Grinder Dustincoc Tools & Equipment 29 07-03-2013 07:34 AM
Why you don't put a saw blade on an angle grinder.... Bearded Wonder Tools & Equipment 44 06-19-2013 05:37 PM
1999 hitachi 5" angle grinder model no.? sepindustries Tools & Equipment 10 06-15-2013 09:11 AM
Mini Ex size rino1494 Excavation & Site Work 24 07-29-2012 05:56 PM
