In Search Of Cement Replacements
Old 10-21-2017, 11:27 AM   #1
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 2,474
"Could we replace cement as the vital element in concrete some day? We look at two alternative answers to this question."
https://aec-business.com/search-ceme...4d026ba2b58612
Big Johnson is online now
SmallTownGuy (10-21-2017)
Old 10-21-2017, 11:42 AM   #2
LRG WoodCrafting
Leo G's Avatar
Trade: Woodworker Extraordinaire
Rewards Points: 8,277
Re: In Search Of Cement Replacements
Gonna be a long time before that happens I bet.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 10-21-2017, 01:46 PM   #3
That's what the calportland guy said in the video. The China statistic was a little hard to believe.
Old 10-21-2017, 02:05 PM   #4
B.Johnson's Avatar
Trade: Builder
Rewards Points: 948
We have a local redi-mix company that supposedly doesn't use cement. I asked them once if I could get a 6 bag mix and they replied that they don't do bag mixes, only PSI. Maybe they don't totally eliminate cement, but I think that they try hard to. The finishers' aren't as fond of their concrete because it has so little cream. The footer and wall guys just want it as cheap as they can get it.
Home Designer Series Software
B.Johnson is online now
Old 10-21-2017, 02:08 PM   #5
They substitute one bag of Portland cement for fly ash or another product (can't recall name). My flat work guy prefers it. I'll dig out a receipt and see what it's called if someone doesn't chime in first.
Old 10-21-2017, 02:15 PM   #6
B.Johnson's Avatar
Trade: Builder
Rewards Points: 948
I hear the word "slag" used a lot. Fly ash is familiar too.
The Following User Says Thank You to B.Johnson For This Useful Post:
Old 10-21-2017, 02:28 PM   #7
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,890
The Finnish concept apparently is for smaller precast, factory produced concrete elements that are common in Europe. - Not ready-mix concrete.
Factory produced concrete has the advantage of doing superior curing under tightly controlled exotic conditions. The used some superior curing in out concrete block plant in the U.S. and made 10,000 psi block with only 5 hours of curing (They had virtually no shrinkage compared to normal curing).
The "revolutionary" concrete still has to undergo many years of testing to prove the durability - real life and not lab accelerated unproven tests.
Dick
concretemasonry is offline
Old 10-21-2017, 03:14 PM   #8
The receipt lists Artevia mix. Not sure what the additive is but my flatty says its designed for stamped concrete but gives a smoother finish on regular work and is easier to work with. I don't know, maybe it's just what he's used to using. He does REALLY good work so I won't question it. Here's the RM's website.
Anyway it all still has mostly Portland cement as its binder.
http://www.consumersconcrete.com/artevia_polished.html
The Following 2 Users Say Thank You to Big Johnson For This Useful Post:
Rio (10-21-2017), SmallTownGuy (10-21-2017)
Old 10-21-2017, 03:41 PM   #9
hdavis's Avatar
Rewards Points: 7,113
Iron carbonate? I'm all for it - how muck does a block weigh, and how do I get the rust stains off it?.....
hdavis is online now
Old 10-21-2017, 05:14 PM   #10
Designer/Contractor
Rio's Avatar
Rewards Points: 1,258
Maybe take some clues from what the Romans used, volcanic ash (pozzolana) and lime, use that as a starting point and go from there
Rio is online now
The Following User Says Thank You to Rio For This Useful Post:
Old 10-21-2017, 05:28 PM   #11
hdavis's Avatar
Looks like we'll need more volcanos.
Old 10-21-2017, 05:30 PM   #12
hdavis's Avatar
What ever happened to geopolymers - some kind of stone dissolved in an acid, then mixed with stone dust to form a solid rock?
Old 10-21-2017, 05:53 PM   #13
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 8,976
be careful what you wish for...
https://www.sciencealert.com/yellows...han-we-thought
SmallTownGuy is online now
The Following User Says Thank You to SmallTownGuy For This Useful Post:
hdavis (10-21-2017)
Old 10-21-2017, 05:59 PM   #14
fjn's Avatar
Trade: mason
Rewards Points: 8,830
It probably is a pozzolan,and more than likely a metakaolin .
fjn is online now
The Following 2 Users Say Thank You to fjn For This Useful Post:
Rio (10-21-2017), Texas Wax (10-22-2017)
Old 10-21-2017, 10:27 PM   #15
Designer/Contractor
Rio's Avatar
I've always been concerned about heavy metal and other contaminants in fly ash being released in concrete made with it, say when it's being ground on or pulverized in some manner but apparently that might be a misguided worry as the article excerpt below mentions.
In fact, when concrete is produced, “much of the fly ash reacts with the Portland cement products of combustion to become, get this—calcium silicate hydrate—the same mineral that gives concrete its strength,” explains Michael Chusid, RA, FCSI, CCS, principal of the Tarzana, Calif.-based architectural technology consulting firm, Chusid Associates. “Any trace amount of heavy metal gets entrapped in the hydrated cement crystals and will have a very difficult time becoming liberated.”
Filling in more details on this unique chemical reaction, David Shepherd, AIA, LEED AP, sustainable development director, Portland Cement Association, Skokie, Ill., explains, “unlike some encapsulation techniques which coat a contaminant with material to ‘glue’ it into place, fly ash chemically reacts with cement during the hydration process and becomes an integral part of the new crystalline structure.”
Consequently, many independent building professionals, and even some environmental groups, are on board with the EPA’s current position that the encapsulated use of fly ash is a very good alternative to sending the ash to the landfills where it faces a greater risk of environmental catastrophe such as the collapse of a Tennessee Valley Authority’s fly ash containment structure in 2008, which sent 5.4 million cubit yards of toxic sludge across 300 acres in Kingston, Tenn.
Rio is online now
SmallTownGuy (10-22-2017)
Old 10-26-2017, 03:46 AM   #16
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 6,145
STG: The hazard of metals in Fly ashes are in general very low, fly ash being the noncombustible remainder of coal, which of course is mostly fossil plant residual, How could plants have that much poisonous metals in them?
And the biggest reason for the lack of heavy metals in fly ash, is they would be extracted if present in any great amount.
But of course fly ash is mildly radioactive as all large coal plants produce much more fall Out radiation then normally operating US Nuke plants....
As the science of Portland Cements improves, they will shrink less, and have greater tensile strength to compression strength ratios, and reinforcement materials and concrete will have closer elasticity properties allowing designers to design lighter < cheaper structural elements.
Fouthgeneration is offline
Old 10-26-2017, 01:38 PM   #17
Stone Guy
Rock Headed's Avatar
Trade: masonry
Rice husk ash.
http://www.sciencedirect.com/science...14509516300924
Renewable. Not radioactive.
Rock Headed is offline
Better Search Function B.Johnson Site Feedback and Suggestions 15 05-16-2017 09:37 AM
Rain washed away flashing roof cement? Pete271 Roofing 4 06-15-2016 01:02 PM
Cement board prep for tile gowings Tiling 28 09-08-2015 07:52 PM
Cement Board outside Morning Wood Masonry 8 02-25-2011 03:02 AM
Anyone with a web site: Search engine tips Grumpy Technology 22 05-23-2009 10:42 AM
