Sealing Interior Brick....which Type Of Sealer?
Old 11-14-2007, 09:16 AM   #1
lukachuki's Avatar
Rewards Points: 1,002
Have a friend who is remodeling a historic building to turn into a restaurant. The interior walls are exposed, really old, really soft, unstruck load bearing walls. My friend is concerned about particulate falling off of the walls and interfering with the happy eating experience he hopes to provide for his clientele. His preference is something that will seal in as much as possible the crap that wants to fall down. So far we have taken a rub brick to remove as much loose mortar as possible, (which really really helped) and then acid washed/scraped to remove the mortar film. They look fine but now we need to seal.
For stamped concrete I use a solvent based 30% solids clear sealer which works real nice on decorative concrete but I'm unsure how it will handle the brick. The manufacturer says they use it on interior brick quite often but I'm a little skeptical.
Any experiences w/ sealer and brick out there?
I'm a little mean, but I make up for it by bein' real healthy. Earnest T. Bass
lukachuki is offline
Old 11-14-2007, 10:06 AM   #2
Tscarborough's Avatar
Rewards Points: 1,392
Re: Sealing Interior Brick....which Type Of Sealer?
It should work fine, just leave enough time for it to cure out and quit reeking.
Tscarborough is offline
Old 11-28-2007, 01:24 PM   #3
roo's Avatar
Trade: Bricklayer
Rewards Points: 75
I don't know what liquids you have in the u.s. but i tend to use PVA mixed with water, it provides a brilliant seal which is clear and not solvent based and if you water it down enough the brick will suck it up, two or three coats of this and the restaurant will be dust free.
roo is offline
Sanding Sealer plumbco Painting & Finish Work 18 01-05-2013 08:48 AM
What type of airhose do you use? Webs Tools & Equipment 18 08-01-2007 08:37 PM
Venting of Cathedral Ceiling on Shed type roof sandyman720 Roofing 4 07-30-2007 08:14 AM
Sanding sealer help birdog Specialty Coatings 5 07-11-2007 09:05 PM
Sealing concrete countertops 6stringmason Masonry 2 12-12-2006 09:07 PM
