Sealing Clay Tile?
Old 02-21-2009, 02:28 PM   #1
look171's Avatar
Trade: cabinet maker, ganeral contractor
Sealing Clay Tile?
What's the best method or type of sealer is best for Saltillo Tiles? Expoy sealer or just off the shelves stuff will do it? I used Ole' sealer in the back of the house, and the tile look like crap in a matter of 2 years under the sun and a little rain. I can't get the dirt off. If i use an epoxy sealer to seal the back of the tile, will that cause it to not stick well or should I just use a water base sealer like 511 for the back?
What's that stuff they use in high traffic areas like the mall? I don't think I want it shiny.
jeff
look171 is offline
Old 02-21-2009, 05:45 PM   #2
Sean
SLSTech's Avatar
Re: Sealing Clay Tile?
Believe it or not - I have seen plenty of places use Motor Oil, it gives it a unique look (edit: Outside Only)
I suggest you try an individual tile for the diffrent type of sealers to see which one you like
SLSTech is offline
Old 02-21-2009, 07:09 PM   #3
Tscarborough's Avatar
My entire house is saltillo, my wife uses orange oil twice a year.
Tscarborough is online now
Old 02-23-2009, 10:21 PM   #4
look171's Avatar
anyone else? a commerical sealer? I am sure they don't use motor or orange oil in those pleces. I know the tile is soft, but I have seen it use in places like restaurants.
look171 is offline
Old 02-24-2009, 08:03 AM   #5
Sean
SLSTech's Avatar
TS - if I get another inside project, I am going to have to try that one
Most restaurants won't use Saltillo inside & if they want the look they will go with a look a like.
Your project is outside - test a few different sealers on individual small pieces & drive around town for a few months with them on your dashboard. See which you like best & seems to hold up the best. Just remember every 6 months or so it will need to be cleaned & resealed
Sorry I have only done a few Saltillo projects before I left AZ & they were always motor oil or some sealer found at HD (can't really recall the name - green container?)
By the way - you need to put your location in your profile, that might help you get a more region specific answer, or check with the company you bought it from
You might also want to have this moved to the tile area instead of the masonry.
SLSTech is offline
Old 02-25-2009, 08:13 AM   #6
tkle's Avatar
Mexisealer, Home Depot/Lowes sells sealers specific for saltillo tile. Regularly applied floor finish over the sealer will protect it from wear. To reseal you need to remove the old sealer or the new sealer won't soak in and will turn out splotchy. I like to throw a little concrete color in it. Personally I like the look of splotchy sealer when it has color in it.
Orange oil sounds interesting. I presume it doesn't soften the tile.
tkle is offline
The Following User Says Thank You to tkle For This Useful Post:
SLSTech (02-25-2009)
Old 08-14-2009, 04:31 PM   #7
throttle1's Avatar
Has anyone ever used polycrylic or another eurothane on indoor installations of saltillo?
throttle1 is offline
Best way to cut clay sewer tile? Williams Ex Co Plumbing 8 12-07-2008 04:50 PM
information on fixing a bad tile job bford General Discussion 4 09-30-2008 07:44 AM
Clay tile roof repair - CT? StephCT Roofing 1 01-03-2008 02:37 PM
Clay tile roof Joewho Painting & Finish Work 7 06-09-2007 08:22 PM
Clay tile roofing Alkyd Roofing 8 11-27-2006 08:43 AM
