Sealing Bsmt Walls And Floor
I have a new house basement that I want to prep for finishing. The moisture level is fairly high in the area and I need a product to apply to the walls and floor that will seal out moisture. They will both be covered, so looks don`t matter. Thanks, Dan
Doing it right the first time is always cheaper. |
Re: Sealing Bsmt Walls And Floor
Hopefully there's a moisture barrier under the slab and behind the walls.
Trade: MASONRY CLEANING/ CONCRETE SURFACE PREP
Xypex has some products that are great for negative side penetration from water.
JIM CARROLL INLET PRESSURE CLEANING MYRTLE BEACH SC |
Trade: waterproofing & restoration
is the moisture coming from the walls or floor plz reply
Drylok works negative side, as does Thoroseal.
