Seal?
Old 11-17-2009, 03:12 PM   #1
lineareagle's Avatar
Question
Seal?
I am looking at a job that will require the construction of a catch basin on top of a concrete floor. The option is either concrete poured or concrete block.
I would prefer concrete block. I have heard that there is a gasket material that can be put between the lower row and the floor to provide a water tight seal but I can find no info on same.
Anyone know of this product?
It will be a 2 row 8" wall 100 feet long with 6 corners, longest wall 23'.
Thanks for any info on this.
lineareagle is offline
Old 11-17-2009, 07:25 PM   #2
CJKarl's Avatar
Trade: Masonry
Re: Seal?
I'm no engineer. but I would lay the block, rake out the bed joint and put in a bead of butyl. What's going to keep the block itself waterproof?
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Old 11-17-2009, 11:27 PM   #3
Rockmonster's Avatar
Trade: Masonry
Re: Seal?
You are probably thinking of bentonite. It comes in rolls for applications something like yours. I have not used it in years, but look into that. Amazing product, but it's expansive properties can limit it's use. Check it...
Rockmonster is online now
Old 11-18-2009, 01:35 AM   #4
NCbrickie
GoToBrick's Avatar
Trade: custom masonry and hardscape
Re: Seal?
I've done a few in slaughter houses and I always go with a pool sealer...just stop at a pool supply or lowes and check them out. water proof and tough and also reasonably priced,you can apply it to the inside face of the blocks and be done with it
Larry
farout@myself.com
http://www.centsports.com/?opcode=665464 ---just paste this to your browser to bet all favorite sport games
GoToBrick is offline
decks...seal entire deck? MAC2PAINTING Painting & Finish Work 1 10-26-2009 07:55 PM
Foam seal sealer dvd Framing 9 10-15-2009 05:39 AM
Epdm Lap Seal thorroofer Roofing 13 09-22-2009 12:47 AM
How to Seal White Mortar Masonry ScottLewis Masonry 2 03-21-2009 07:50 PM
seal gaps in attic? mrself Construction 4 01-04-2009 05:05 PM
