LC Australia
Trade: Building
Salt Attack!
Got a problem.
How can you stop staining and salt attack in masonry/brick work? You know what i mean, when it goes white. thanks
"It's better to die on your feet than to live on your knees" |
Trade: Masonry consultant
Re: Salt Attack!
It is not salt attck and it is not a stain.
It is called efflorescence, which occurs when you have moisture in the wall and it deposits salts on the surface as the moisture evaporates. It takes moisture and soluable salts. To eliminate efflorescence, don't get water in the masonry. You can't eliminate the salt (usually calcium carbonate. etc.). Efflorescence will decrease with time. It is an indicator that there is moisture in the wall and it is coming out.
Dick Engineer, designer and consultant recently active domestically and internationally on construction and design in about 35 countries. |
| Salt System on a Hot Tub | Hurley | Pool Construction & Enclosures | 13 | 04-05-2007 12:06 AM |
| Water softeners | JamesNLA | Plumbing | 0 | 02-24-2007 09:31 PM |
| The great war poll | Glasshousebltr | Off Topic (Non Trade) | 510 | 08-06-2006 10:35 PM |
| Salt in Well Water | naturenut | General Discussion | 10 | 11-12-2005 08:13 PM |
| Painting Salt Treated Wood | CoastalCoatings | Painting & Finish Work | 2 | 10-13-2005 09:05 AM |
